PeterO
Example Code
Thu Feb 14, 2013 8:29 pm
I've put a simple(ish) example on my web site: http://www.peteronion.org.uk/OpenGLES/C-openGLES.1.tgz
There's a CMakeLists.txt file included so you'll need the cmake package installed to rebuild(*) the executable if you want to change anything,
Please report any problems here.
PeterO
(*) In the C-openGLES directory run "cmake ." then "make"
panik
Re: Example Code
Fri Feb 15, 2013 8:49 pm
Wow, very clear and simple example. Great comments in Ex1.c. Thanks so much for sharing, PeterO.
I have a question about this code in the Draw() function:
    // These will be needed later......
#if 0
    glViewport(0,0,displayWidth,displayHeight);
    glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
    glEnable(GL_DEPTH_TEST);
    glDepthMask(GL_TRUE);
    glColorMask(GL_TRUE, GL_TRUE, GL_TRUE, GL_TRUE);
#endif
It seems to me that this code is needed only once (in the InitScene() function?), not every frame. Except for glClear() maybe, but I'm not sure. And what do you mean by 'This will be needed later...'? Enabling it doesn't seem to make a difference.
Thanks again, I'm still struggling a bit to make the transition from GLES1 to GLES2, and this will certainly help.
PeterO
Re: Example Code
Fri Feb 15, 2013 9:15 pm
I hoped someone would find it useful :D
"This will be needed later" was a note to me not to delete it. It is there in Ex1.c but isn't used. I should have take it out of Ex1.c (Infact I'll go and take it out now...... Done ;) ).
However it is used in Ex2.c which I'm writing at this moment.
PeterO
panik
Re: Example Code
Fri Feb 15, 2013 9:24 pm
Cool, I'll delete it too.
Looking forward to Ex2.c! :D
PeterO
Re: Example Code
Thu Feb 28, 2013 9:42 pm
Not quite the Ex2 I intended...
http://www.peteronion.org.uk/OpenGLES/rubikCube.tgz
No user interaction yet, and source code to follow....
PeterO
PeterO
Re: Example Code
Sun Mar 10, 2013 3:17 pm
I've uploaded a new version of the tarball that includes all the source code.
I had lots of trouble trying to get the user controlled rotations of the cube to work, until I realised I was going about it in completely the wrong fashion......
Mouse motion will rotate the cube, left and right buttons rotate the front face.
Keyboard controls: Cursor keys rotate the cube, "I" resets cube to initial position, "Q" quits, "Z" and "X" rotate the front face Note control-C will not work.
PeterO
Return to “OpenGLES”
