eglInitialize
Posted: Wed Feb 05, 2020 12:59 pm
by corjan
I downloaded the latest Buster release, and compiled our openGL ES2 code (without Desktop) that was working on an older Jessie build.
On the Buster release though, the eglInitialize returns EGL_NOT_INITIALIZED. The documentation says that the display cannot be initialized.
https://www.khronos.org/registry/EGL/sd ... lize.xhtml
The code I use is around the EGL and vc_dispmanx_ functions, very similar to this:
https://github.com/peepo/openGL-RPi-tut ... Screen.cpp
Is this something that should be backwards compatible on Buster, or should I stick with Jessie for the Pi 3 and 2?
Corjan
Re: eglInitialize
Posted: Wed Feb 05, 2020 1:43 pm
by Daniel Gessel
Which driver are you running? Legacy, FKMS or KMS?
Re: eglInitialize
Posted: Wed Feb 05, 2020 2:38 pm
by fruitoftheloom
Corjan
Raspbian Stretch / Buster is considerably different to Wheezy / Jessie.
Therefore as even Stretch is approaching end of life, it is worth pursuing fixing in Buster.
Re: eglInitialize
Posted: Wed Feb 05, 2020 3:05 pm
by corjan
HI,
Thanks for your response!
It is set to the default, Legacy.
I would like to update to Buster, but this is preventing me from doing so unfortunately. Ironically, it works fine now on the Pi 4 :).
Corjan
Re: eglInitialize
Posted: Wed Feb 05, 2020 3:27 pm
by Daniel Gessel
Hmm, that throws me as I thought the dispmanx stuff didn’t work on Pi4 and maybe Buster was defaulting to fKMS on Pi3...
My understanding is we’re all supposed to migrate to KMS, so I started there and don’t have enough experience with dispmanx to help. The reference sample for kms seems to be kmscube, in case you want to consider it.
