best way to monitor framerate with drm?
Posted: Mon Feb 03, 2020 9:06 pm
by jvcleave
I am writing a drm based app and I seem to be capped at 30fps even though my drmModeModeInfo refresh returns 60fps
I am looking for something like this
https://wiki.st.com/stm32mpu/wiki/DRM_K ... _framerate
Re: best way to monitor framerate with drm?
Posted: Tue Feb 04, 2020 11:27 am
by 6by9
From that ST page you link to
The DRM/KMS framework does not offer natively a display framerate monitoring, the above solution is powered by the STMicroelectronics DRM/KMS implementation.
https://github.com/raspberrypi/linux/bl ... tdc.c#L885 is presumably the logging lines they are looking at. That's the number of updates per plane, not per display. You could add a similar thing to vc4 - PRs welcome.
Posted: Tue Feb 04, 2020 5:28 pm
by jvcleave
Thanks! Is it odd that I don't get 60fps with kmscube in legacy mode? I've even reduced the drawing to just glClear
Posted: Tue Feb 04, 2020 5:45 pm
by 6by9
jvcleave wrote: ↑Tue Feb 04, 2020 5:28 pm
Pi4 or Pi3?
If Pi4 then you've dropped back to software GL, and that will be slow.
Posted: Tue Feb 04, 2020 5:55 pm
by jvcleave
It's a PI4 (X not running)
OpenGL ES 2.x information:
version: "OpenGL ES 3.0 Mesa 19.2.0-rc1"
shading language version: "OpenGL ES GLSL ES 3.00"
vendor: "Broadcom"
renderer: "V3D 4.2"
Posted: Wed Feb 05, 2020 7:56 am
by jvcleave
not sure what but something with kmscube is different than this similar implementation that runs at 60fps
https://github.com/matusnovak/rpi-opengl-without-x
Posted: Wed Feb 05, 2020 8:16 am
by Gavinmc42
With two screens, could the other be used as debug output, ie fps etc.
Can piglet be used?
I am so far down the learning curve I am on flat ground, I have to use things like this for inspiration.
https://www.iquilezles.org/www/index.htm
Godot4 will have a CPU/GPU profiler, that will be useful one day.
