Skin Mesh Animation
Posted: Sat Dec 21, 2019 3:18 pm
I'm trying to get my 3D engine to work on GLES.
There is something wrong with the shaders and the program spits out a bunch of assembly at me but I'm not versed enough to understand what it means:
Fragment
Vertex
Assembly from GLSL? on cerr
Google gives nothing, has anyone published working skin mesh shaders anywhere on the internet for GLES?
Fragment
#version 100
precision lowp float;
varying vec2 outTexCoord;
varying vec3 out_Normal;
uniform sampler2D texUnit;
varying float red;
varying float green;
varying float blue;
void main(void) {
vec3 light = vec3(0, 0, 6); // in view coordinates
vec4 color = vec4(0.5, 0.5, 0.5, 1.0);
vec3 normal = normalize(out_Normal);
float intensity = dot(light, normal);
if (intensity > 0.95)
color = vec4(1.0, 1.0, 1.0, 1.0);
else if (intensity > 0.8)
color = vec4(0.8, 0.8, 0.8, 1.0);
else if (intensity > 0.6)
color = vec4(0.6, 0.6, 0.6, 1.0);
else
gl_FragColor = color * texture2D(texUnit, outTexCoord);
#version 100
precision highp float;
attribute vec3 in_Position;
attribute vec3 in_Normal;
attribute vec2 in_TexCoord;
attribute vec4 in_Weights;
attribute float in_nrBones;
attribute vec4 in_whichBones;
uniform mat4 modelMatrix;
uniform mat4 viewMatrix;
uniform mat4 projMatrix;
uniform mat4 skinningMatrix[50];
void main(void) {
int nrBones = int(in_nrBones);
vec4 boneIndex = in_whichBones;
vec4 weight = in_Weights;
outTexCoord = in_TexCoord;
vec4 tempPosition = vec4(0.0, 0.0, 0.0, 0.0);
vec4 tempNormal = vec4(0.0, 0.0, 0.0, 0.0);
mat4 tempMatrix;
for (int i = 0; i < 4; i++) {
tempMatrix = weight.x * skinningMatrix[int(boneIndex.x)];
tempPosition += tempMatrix * vec4(in_Position, 1.0);
tempNormal += tempMatrix * vec4(in_Normal, 0.0);
weight = vec4(weight.yzw, weight.x); //rotate weight
boneIndex = vec4(boneIndex.yzw, boneIndex.x); //rotate bone
out_Normal = vec3(tempNormal);
gl_Position = projMatrix * viewMatrix * modelMatrix * tempPosition;
Failed to register allocate:
BLOCK 0:
0 S 0 mov t0, vpm0.0
1 S 1 mov t1, vpm0.1
2 S 2 mov t2, vpm0.2
3 S 3 mov t3, vpm1.0
4 S 4 mov t4, vpm1.1
5 S 5 mov t5, vpm1.2
6 S 6 mov t6, vpm2.0
7 S 7 mov t7, vpm2.1
8 S 8 mov t8, vpm3.0
9 S 9 mov t9, vpm3.1
10 S 10 mov t10, vpm3.2
11 S 11 mov t11, vpm3.3
12 S 32 ftoi t32, vpm4.0
13 S 33 E 32 shl t33, t32, 6
13 S 34 max t34, t33, 0
14 S 35 E 34 min_noimm t35, t34, u0 (0x00000c7c / 0.000000)
14 E 35 add tex_s_direct, t35, u1 (??? 12)
13 S 37 max t37, t33, 0
14 S 38 E 37 min_noimm t38, t37, u2 (0x00000c78 / 0.000000)
14 E 38 add tex_s_direct, t38, u3 (??? 12)
13 S 40 max t40, t33, 0
14 S 41 E 40 min_noimm t41, t40, u4 (0x00000c74 / 0.000000)
14 E 41 add tex_s_direct, t41, u5 (??? 12)
13 S 43 max t43, t33, 0
14 S 44 E 43 min_noimm t44, t43, u6 (0x00000c70 / 0.000000)
14 E 44 add tex_s_direct, t44, u7 (??? 12)
13 S 50 add t50, t33, u8 (0x00000010 / 0.000000)
14 S 51 max t51, t50, 0
15 S 52 E 51 min_noimm t52, t51, u9 (0x00000c7c / 0.000000)
15 S 36 tex_result t36
16 E 52 add tex_s_direct, t52, u10 (??? 12)
15 S 54 max t54, t50, 0
16 S 55 E 54 min_noimm t55, t54, u11 (0x00000c78 / 0.000000)
16 S 39 tex_result t39
17 E 55 add tex_s_direct, t55, u12 (??? 12)
16 S 57 max t57, t50, 0
17 S 58 E 57 min_noimm t58, t57, u13 (0x00000c74 / 0.000000)
17 S 42 tex_result t42
18 E 58 add tex_s_direct, t58, u14 (??? 12)
17 S 60 E 50 max t60, t50, 0
17 S 61 E 60 min_noimm t61, t60, u15 (0x00000c70 / 0.000000)
17 S 45 tex_result t45
18 E 61 add tex_s_direct, t61, u16 (??? 12)
17 S 67 add t67, t33, u17 (0x00000020 / 0.000000)
18 S 68 max t68, t67, 0
19 S 69 E 68 min_noimm t69, t68, u18 (0x00000c7c / 0.000000)
19 S 53 tex_result t53
20 E 69 add tex_s_direct, t69, u19 (??? 12)
19 S 71 max t71, t67, 0
20 S 72 E 71 min_noimm t72, t71, u20 (0x00000c78 / 0.000000)
20 S 56 tex_result t56
21 E 72 add tex_s_direct, t72, u21 (??? 12)
20 S 74 max t74, t67, 0
21 S 75 E 74 min_noimm t75, t74, u22 (0x00000c74 / 0.000000)
21 S 59 tex_result t59
22 E 75 add tex_s_direct, t75, u23 (??? 12)
21 S 77 E 67 max t77, t67, 0
21 S 78 E 77 min_noimm t78, t77, u24 (0x00000c70 / 0.000000)
21 S 62 tex_result t62
22 E 78 add tex_s_direct, t78, u25 (??? 12)
21 S 84 E 33 add t84, t33, u26 (0x00000030 / 0.000000)
21 S 85 max t85, t84, 0
22 S 86 E 85 min_noimm t86, t85, u27 (0x00000c7c / 0.000000)
22 S 70 tex_result t70
23 E 86 add tex_s_direct, t86, u28 (??? 12)
22 S 88 max t88, t84, 0
23 S 89 E 88 min_noimm t89, t88, u29 (0x00000c78 / 0.000000)
23 S 73 tex_result t73
24 E 89 add tex_s_direct, t89, u30 (??? 12)
23 S 91 max t91, t84, 0
24 S 92 E 91 min_noimm t92, t91, u31 (0x00000c74 / 0.000000)
24 S 76 tex_result t76
25 E 92 add tex_s_direct, t92, u32 (??? 12)
24 S 94 E 84 max t94, t84, 0
24 S 95 E 94 min_noimm t95, t94, u33 (0x00000c70 / 0.000000)
24 S 79 tex_result t79
25 E 95 add tex_s_direct, t95, u34 (??? 12)
24 S 140 ftoi t140, vpm4.1
25 S 141 E 140 shl t141, t140, 6
25 S 142 max t142, t141, 0
26 S 143 E 142 min_noimm t143, t142, u35 (0x00000c7c / 0.000000)
26 S 87 tex_result t87
27 E 143 add tex_s_direct, t143, u36 (??? 12)
26 S 145 max t145, t141, 0
27 S 146 E 145 min_noimm t146, t145, u37 (0x00000c78 / 0.000000)
27 S 90 tex_result t90
28 E 146 add tex_s_direct, t146, u38 (??? 12)
27 S 148 max t148, t141, 0
28 S 149 E 148 min_noimm t149, t148, u39 (0x00000c74 / 0.000000)
28 S 93 tex_result t93
29 E 149 add tex_s_direct, t149, u40 (??? 12)
28 S 151 max t151, t141, 0
29 S 152 E 151 min_noimm t152, t151, u41 (0x00000c70 / 0.000000)
29 S 96 tex_result t96
30 E 152 add tex_s_direct, t152, u42 (??? 12)
29 S 158 add t158, t141, u43 (0x00000010 / 0.000000)
30 S 159 max t159, t158, 0
31 S 160 E 159 min_noimm t160, t159, u44 (0x00000c7c / 0.000000)
31 S 144 tex_result t144
32 E 160 add tex_s_direct, t160, u45 (??? 12)
31 S 162 max t162, t158, 0
32 S 163 E 162 min_noimm t163, t162, u46 (0x00000c78 / 0.000000)
32 S 147 tex_result t147
33 E 163 add tex_s_direct, t163, u47 (??? 12)
32 S 165 max t165, t158, 0
33 S 166 E 165 min_noimm t166, t165, u48 (0x00000c74 / 0.000000)
33 S 150 tex_result t150
34 E 166 add tex_s_direct, t166, u49 (??? 12)
33 S 168 E 158 max t168, t158, 0
33 S 169 E 168 min_noimm t169, t168, u50 (0x00000c70 / 0.000000)
33 S 153 tex_result t153
34 E 169 add tex_s_direct, t169, u51 (??? 12)
33 S 175 add t175, t141, u52 (0x00000020 / 0.000000)
34 S 176 max t176, t175, 0
35 S 177 E 176 min_noimm t177, t176, u53 (0x00000c7c / 0.000000)
35 S 161 tex_result t161
36 E 177 add tex_s_direct, t177, u54 (??? 12)
35 S 179 max t179, t175, 0
36 S 180 E 179 min_noimm t180, t179, u55 (0x00000c78 / 0.000000)
36 S 164 tex_result t164
37 E 180 add tex_s_direct, t180, u56 (??? 12)
36 S 182 max t182, t175, 0
37 S 183 E 182 min_noimm t183, t182, u57 (0x00000c74 / 0.000000)
37 S 167 tex_result t167
38 E 183 add tex_s_direct, t183, u58 (??? 12)
37 S 185 E 175 max t185, t175, 0
37 S 186 E 185 min_noimm t186, t185, u59 (0x00000c70 / 0.000000)
37 S 170 tex_result t170
38 E 186 add tex_s_direct, t186, u60 (??? 12)
37 S 192 E 141 add t192, t141, u61 (0x00000030 / 0.000000)
37 S 193 max t193, t192, 0
38 S 194 E 193 min_noimm t194, t193, u62 (0x00000c7c / 0.000000)
38 S 178 tex_result t178
39 E 194 add tex_s_direct, t194, u63 (??? 12)
38 S 196 max t196, t192, 0
39 S 197 E 196 min_noimm t197, t196, u64 (0x00000c78 / 0.000000)
39 S 181 tex_result t181
40 E 197 add tex_s_direct, t197, u65 (??? 12)
39 S 199 max t199, t192, 0
40 S 200 E 199 min_noimm t200, t199, u66 (0x00000c74 / 0.000000)
40 S 184 tex_result t184
41 E 200 add tex_s_direct, t200, u67 (??? 12)
40 S 202 E 192 max t202, t192, 0
40 S 203 E 202 min_noimm t203, t202, u68 (0x00000c70 / 0.000000)
40 S 187 tex_result t187
41 E 203 add tex_s_direct, t203, u69 (??? 12)
40 S 255 ftoi t255, vpm4.2
41 S 256 E 255 shl t256, t255, 6
41 S 257 max t257, t256, 0
42 S 258 E 257 min_noimm t258, t257, u70 (0x00000c7c / 0.000000)
42 S 195 tex_result t195
43 E 258 add tex_s_direct, t258, u71 (??? 12)
42 S 260 max t260, t256, 0
43 S 261 E 260 min_noimm t261, t260, u72 (0x00000c78 / 0.000000)
43 S 198 tex_result t198
44 E 261 add tex_s_direct, t261, u73 (??? 12)
43 S 263 max t263, t256, 0
44 S 264 E 263 min_noimm t264, t263, u74 (0x00000c74 / 0.000000)
44 S 201 tex_result t201
45 E 264 add tex_s_direct, t264, u75 (??? 12)
44 S 266 max t266, t256, 0
45 S 267 E 266 min_noimm t267, t266, u76 (0x00000c70 / 0.000000)
45 S 204 tex_result t204
46 E 267 add tex_s_direct, t267, u77 (??? 12)
45 S 273 add t273, t256, u78 (0x00000010 / 0.000000)
46 S 274 max t274, t273, 0
47 S 275 E 274 min_noimm t275, t274, u79 (0x00000c7c / 0.000000)
47 S 259 tex_result t259
48 E 275 add tex_s_direct, t275, u80 (??? 12)
47 S 277 max t277, t273, 0
48 S 278 E 277 min_noimm t278, t277, u81 (0x00000c78 / 0.000000)
48 S 262 tex_result t262
49 E 278 add tex_s_direct, t278, u82 (??? 12)
48 S 280 max t280, t273, 0
49 S 281 E 280 min_noimm t281, t280, u83 (0x00000c74 / 0.000000)
49 S 265 tex_result t265
50 E 281 add tex_s_direct, t281, u84 (??? 12)
49 S 283 E 273 max t283, t273, 0
49 S 284 E 283 min_noimm t284, t283, u85 (0x00000c70 / 0.000000)
49 S 268 tex_result t268
50 E 284 add tex_s_direct, t284, u86 (??? 12)
49 S 290 add t290, t256, u87 (0x00000020 / 0.000000)
50 S 291 max t291, t290, 0
51 S 292 E 291 min_noimm t292, t291, u88 (0x00000c7c / 0.000000)
51 S 276 tex_result t276
52 E 292 add tex_s_direct, t292, u89 (??? 12)
51 S 294 max t294, t290, 0
52 S 295 E 294 min_noimm t295, t294, u90 (0x00000c78 / 0.000000)
52 S 279 tex_result t279
53 E 295 add tex_s_direct, t295, u91 (??? 12)
52 S 297 max t297, t290, 0
53 S 298 E 297 min_noimm t298, t297, u92 (0x00000c74 / 0.000000)
53 S 282 tex_result t282
54 E 298 add tex_s_direct, t298, u93 (??? 12)
53 S 300 E 290 max t300, t290, 0
53 S 301 E 300 min_noimm t301, t300, u94 (0x00000c70 / 0.000000)
53 S 285 tex_result t285
54 E 301 add tex_s_direct, t301, u95 (??? 12)
53 S 307 E 256 add t307, t256, u96 (0x00000030 / 0.000000)
53 S 308 max t308, t307, 0
54 S 309 E 308 min_noimm t309, t308, u97 (0x00000c7c / 0.000000)
54 S 293 tex_result t293
55 E 309 add tex_s_direct, t309, u98 (??? 12)
54 S 311 max t311, t307, 0
55 S 312 E 311 min_noimm t312, t311, u99 (0x00000c78 / 0.000000)
55 S 296 tex_result t296
56 E 312 add tex_s_direct, t312, u100 (??? 12)
55 S 314 max t314, t307, 0
56 S 315 E 314 min_noimm t315, t314, u101 (0x00000c74 / 0.000000)
56 S 299 tex_result t299
57 E 315 add tex_s_direct, t315, u102 (??? 12)
56 S 317 E 307 max t317, t307, 0
56 S 318 E 317 min_noimm t318, t317, u103 (0x00000c70 / 0.000000)
56 S 302 tex_result t302
57 E 318 add tex_s_direct, t318, u104 (??? 12)
56 S 370 ftoi t370, vpm4.3
57 S 371 E 370 shl t371, t370, 6
57 S 372 max t372, t371, 0
58 S 373 E 372 min_noimm t373, t372, u105 (0x00000c7c / 0.000000)
58 S 310 tex_result t310
59 E 373 add tex_s_direct, t373, u106 (??? 12)
58 S 375 max t375, t371, 0
59 S 376 E 375 min_noimm t376, t375, u107 (0x00000c78 / 0.000000)
59 S 313 tex_result t313
60 E 376 add tex_s_direct, t376, u108 (??? 12)
59 S 378 max t378, t371, 0
60 S 379 E 378 min_noimm t379, t378, u109 (0x00000c74 / 0.000000)
60 S 316 tex_result t316
61 E 379 add tex_s_direct, t379, u110 (??? 12)
60 S 381 max t381, t371, 0
61 S 382 E 381 min_noimm t382, t381, u111 (0x00000c70 / 0.000000)
61 S 319 tex_result t319
62 E 382 add tex_s_direct, t382, u112 (??? 12)
61 S 388 add t388, t371, u113 (0x00000010 / 0.000000)
62 S 389 max t389, t388, 0
63 S 390 E 389 min_noimm t390, t389, u114 (0x00000c7c / 0.000000)
63 S 374 tex_result t374
64 E 390 add tex_s_direct, t390, u115 (??? 12)
63 S 392 max t392, t388, 0
64 S 393 E 392 min_noimm t393, t392, u116 (0x00000c78 / 0.000000)
64 S 377 tex_result t377
65 E 393 add tex_s_direct, t393, u117 (??? 12)
64 S 395 max t395, t388, 0
65 S 396 E 395 min_noimm t396, t395, u118 (0x00000c74 / 0.000000)
65 S 380 tex_result t380
66 E 396 add tex_s_direct, t396, u119 (??? 12)
65 S 398 E 388 max t398, t388, 0
65 S 399 E 398 min_noimm t399, t398, u120 (0x00000c70 / 0.000000)
65 S 383 tex_result t383
66 E 399 add tex_s_direct, t399, u121 (??? 12)
65 S 46 E 36 fmul t46, t36, t8
65 S 63 E 53 fmul t63, t53, t8
65 S 101 fmul t101, t46, t0
66 S 105 fmul t105, t63, t1
67 S 109 E 101, E 105 fadd t109, t101, t105
66 S 125 E 46 fmul t125, t46, t3
66 S 128 E 63 fmul t128, t63, t4
66 S 131 E 125, E 128 fadd t131, t125, t128
65 S 405 add t405, t371, u122 (0x00000020 / 0.000000)
66 S 406 max t406, t405, 0
67 S 407 E 406 min_noimm t407, t406, u123 (0x00000c7c / 0.000000)
67 S 391 tex_result t391
68 E 407 add tex_s_direct, t407, u124 (??? 12)
67 S 409 max t409, t405, 0
68 S 410 E 409 min_noimm t410, t409, u125 (0x00000c78 / 0.000000)
68 S 394 tex_result t394
69 E 410 add tex_s_direct, t410, u126 (??? 12)
68 S 412 max t412, t405, 0
69 S 413 E 412 min_noimm t413, t412, u127 (0x00000c74 / 0.000000)
69 S 397 tex_result t397
70 E 413 add tex_s_direct, t413, u128 (??? 12)
69 S 415 E 405 max t415, t405, 0
69 S 416 E 415 min_noimm t416, t415, u129 (0x00000c70 / 0.000000)
69 S 400 tex_result t400
70 E 416 add tex_s_direct, t416, u130 (??? 12)
69 S 47 E 39 fmul t47, t39, t8
69 S 64 E 56 fmul t64, t56, t8
69 S 102 fmul t102, t47, t0
70 S 106 fmul t106, t64, t1
71 S 110 E 102, E 106 fadd t110, t102, t106
70 S 48 E 42 fmul t48, t42, t8
70 S 65 E 59 fmul t65, t59, t8
70 S 103 fmul t103, t48, t0
71 S 107 fmul t107, t65, t1
72 S 111 E 103, E 107 fadd t111, t103, t107
71 S 49 E 45 fmul t49, t45, t8
71 S 104 E 49 fmul t104, t49, t0
71 S 66 E 62 fmul t66, t62, t8
71 S 108 E 66 fmul t108, t66, t1
71 S 112 E 104, E 108 fadd t112, t104, t108
70 S 80 E 70 fmul t80, t70, t8
70 S 113 fmul t113, t80, t2
71 S 117 E 109, E 113 fadd t117, t109, t113
70 S 134 E 80 fmul t134, t80, t5
70 S 137 E 131, E 134 fadd t137, t131, t134
69 S 81 E 73 fmul t81, t73, t8
69 S 114 fmul t114, t81, t2
70 S 118 E 110, E 114 fadd t118, t110, t114
69 S 82 E 76 fmul t82, t76, t8
69 S 115 fmul t115, t82, t2
70 S 119 E 111, E 115 fadd t119, t111, t115
69 S 83 E 79 fmul t83, t79, t8
69 S 116 E 83 fmul t116, t83, t2
69 S 120 E 112, E 116 fadd t120, t112, t116
68 S 97 E 87 fmul t97, t87, t8
68 S 121 E 97, E 117 fadd t121, t117, t97
67 S 98 E 90 fmul t98, t90, t8
67 S 122 E 98, E 118 fadd t122, t118, t98
66 S 99 E 93 fmul t99, t93, t8
66 S 100 E 8, E 96 fmul t100, t96, t8
65 S 123 E 99, E 119 fadd t123, t119, t99
64 S 124 E 100, E 120 fadd t124, t120, t100
63 S 154 E 144 fmul t154, t144, t9
63 S 171 E 161 fmul t171, t161, t9
63 S 237 fmul t237, t154, t3
64 S 240 fmul t240, t171, t4
65 S 243 E 237, E 240 fadd t243, t237, t240
64 S 209 E 154 fmul t209, t154, t0
64 S 213 E 171 fmul t213, t171, t1
64 S 217 E 209, E 213 fadd t217, t209, t213
63 S 155 E 147 fmul t155, t147, t9
63 S 172 E 164 fmul t172, t164, t9
63 S 210 fmul t210, t155, t0
64 S 214 fmul t214, t172, t1
65 S 218 E 210, E 214 fadd t218, t210, t214
64 S 156 E 150 fmul t156, t150, t9
64 S 173 E 167 fmul t173, t167, t9
64 S 211 fmul t211, t156, t0
65 S 215 fmul t215, t173, t1
66 S 219 E 211, E 215 fadd t219, t211, t215
65 S 157 E 153 fmul t157, t153, t9
65 S 212 E 157 fmul t212, t157, t0
65 S 174 E 170 fmul t174, t170, t9
65 S 216 E 174 fmul t216, t174, t1
65 S 220 E 212, E 216 fadd t220, t212, t216
64 S 188 E 178 fmul t188, t178, t9
64 S 246 fmul t246, t188, t5
65 S 249 E 243, E 246 fadd t249, t243, t246
64 S 221 E 188 fmul t221, t188, t2
64 S 225 E 217, E 221 fadd t225, t217, t221
63 S 189 E 181 fmul t189, t181, t9
63 S 222 fmul t222, t189, t2
64 S 226 E 218, E 222 fadd t226, t218, t222
63 S 252 E 137, E 249 fadd t252, t137, t249
62 S 190 E 184 fmul t190, t184, t9
62 S 223 fmul t223, t190, t2
63 S 227 E 219, E 223 fadd t227, t219, t223
62 S 191 E 187 fmul t191, t187, t9
62 S 224 E 191 fmul t224, t191, t2
62 S 228 E 220, E 224 fadd t228, t220, t224
61 S 205 E 195 fmul t205, t195, t9
61 S 229 E 205, E 225 fadd t229, t225, t205
60 S 206 E 198 fmul t206, t198, t9
60 S 230 E 206, E 226 fadd t230, t226, t206
59 S 233 E 121, E 229 fadd t233, t121, t229
58 S 207 E 201 fmul t207, t201, t9
58 S 208 E 9, E 204 fmul t208, t204, t9
57 S 231 E 207, E 227 fadd t231, t227, t207
56 S 234 E 122, E 230 fadd t234, t122, t230
55 S 422 E 371 add t422, t371, u131 (0x00000030 / 0.000000)
55 S 423 max t423, t422, 0
56 S 424 E 423 min_noimm t424, t423, u132 (0x00000c7c / 0.000000)
56 S 408 tex_result t408
57 E 424 add tex_s_direct, t424, u133 (??? 12)
56 S 426 max t426, t422, 0
57 S 427 E 426 min_noimm t427, t426, u134 (0x00000c78 / 0.000000)
57 S 411 tex_result t411
58 E 427 add tex_s_direct, t427, u135 (??? 12)
57 S 429 max t429, t422, 0
58 S 430 E 429 min_noimm t430, t429, u136 (0x00000c74 / 0.000000)
58 S 414 tex_result t414
59 E 430 add tex_s_direct, t430, u137 (??? 12)
58 S 432 E 422 max t432, t422, 0
58 S 433 E 432 min_noimm t433, t432, u138 (0x00000c70 / 0.000000)
58 S 417 tex_result t417
59 E 433 add tex_s_direct, t433, u139 (??? 12)
58 S 232 E 208, E 228 fadd t232, t228, t208
57 S 235 E 123, E 231 fadd t235, t123, t231
56 S 236 E 124, E 232 fadd t236, t124, t232
55 S 269 E 259 fmul t269, t259, t10
55 S 286 E 276 fmul t286, t276, t10
55 S 352 fmul t352, t269, t3
56 S 355 fmul t355, t286, t4
57 S 358 E 352, E 355 fadd t358, t352, t355
56 S 324 E 269 fmul t324, t269, t0
56 S 328 E 286 fmul t328, t286, t1
56 S 332 E 324, E 328 fadd t332, t324, t328
55 S 270 E 262 fmul t270, t262, t10
55 S 287 E 279 fmul t287, t279, t10
55 S 325 fmul t325, t270, t0
56 S 329 fmul t329, t287, t1
57 S 333 E 325, E 329 fadd t333, t325, t329
56 S 271 E 265 fmul t271, t265, t10
56 S 288 E 282 fmul t288, t282, t10
56 S 326 fmul t326, t271, t0
57 S 330 fmul t330, t288, t1
58 S 334 E 326, E 330 fadd t334, t326, t330
57 S 272 E 268 fmul t272, t268, t10
57 S 327 E 272 fmul t327, t272, t0
57 S 289 E 285 fmul t289, t285, t10
57 S 331 E 289 fmul t331, t289, t1
57 S 335 E 327, E 331 fadd t335, t327, t331
56 S 303 E 293 fmul t303, t293, t10
56 S 361 fmul t361, t303, t5
57 S 364 E 358, E 361 fadd t364, t358, t361
56 S 336 E 303 fmul t336, t303, t2
56 S 340 E 332, E 336 fadd t340, t332, t336
55 S 304 E 296 fmul t304, t296, t10
55 S 337 fmul t337, t304, t2
56 S 341 E 333, E 337 fadd t341, t333, t337
55 S 367 E 252, E 364 fadd t367, t252, t364
54 S 305 E 299 fmul t305, t299, t10
54 S 338 fmul t338, t305, t2
55 S 342 E 334, E 338 fadd t342, t334, t338
54 S 306 E 302 fmul t306, t302, t10
54 S 339 E 306 fmul t339, t306, t2
54 S 343 E 335, E 339 fadd t343, t335, t339
53 S 320 E 310 fmul t320, t310, t10
53 S 344 E 320, E 340 fadd t344, t340, t320
52 S 321 E 313 fmul t321, t313, t10
52 S 345 E 321, E 341 fadd t345, t341, t321
51 S 348 E 233, E 344 fadd t348, t233, t344
50 S 322 E 316 fmul t322, t316, t10
50 S 323 E 10, E 319 fmul t323, t319, t10
49 S 346 E 322, E 342 fadd t346, t342, t322
48 S 349 E 234, E 345 fadd t349, t234, t345
47 S 347 E 323, E 343 fadd t347, t343, t323
46 S 350 E 235, E 346 fadd t350, t235, t346
45 S 351 E 236, E 347 fadd t351, t236, t347
44 S 384 E 374 fmul t384, t374, t11
44 S 401 E 391 fmul t401, t391, t11
44 S 439 fmul t439, t384, t0
45 S 443 fmul t443, t401, t1
46 S 447 E 439, E 443 fadd t447, t439, t443
45 S 467 E 384 fmul t467, t384, t3
45 S 470 E 401 fmul t470, t401, t4
45 S 473 E 467, E 470 fadd t473, t467, t470
44 S 385 E 377 fmul t385, t377, t11
44 S 402 E 394 fmul t402, t394, t11
44 S 440 fmul t440, t385, t0
45 S 444 fmul t444, t402, t1
46 S 448 E 440, E 444 fadd t448, t440, t444
45 S 386 E 380 fmul t386, t380, t11
45 S 387 E 383 fmul t387, t383, t11
45 S 442 E 387 fmul t442, t387, t0
45 S 441 E 0 fmul t441, t386, t0
45 S 403 E 397 fmul t403, t397, t11
45 S 404 E 400 fmul t404, t400, t11
45 S 446 E 404 fmul t446, t404, t1
45 S 445 E 1 fmul t445, t403, t1
45 S 449 E 441, E 445 fadd t449, t441, t445
44 S 450 E 442, E 446 fadd t450, t442, t446
43 S 418 E 408 fmul t418, t408, t11
43 S 451 fmul t451, t418, t2
44 S 455 E 447, E 451 fadd t455, t447, t451
43 S 476 E 418 fmul t476, t418, t5
43 S 479 E 473, E 476 fadd t479, t473, t476
42 S 419 E 411 fmul t419, t411, t11
42 S 452 fmul t452, t419, t2
43 S 456 E 448, E 452 fadd t456, t448, t452
42 S 420 E 414 fmul t420, t414, t11
42 S 421 E 417 fmul t421, t417, t11
42 S 454 E 421 fmul t454, t421, t2
42 S 453 E 2 fmul t453, t420, t2
42 S 457 E 449, E 453 fadd t457, t449, t453
41 S 458 E 450, E 454 fadd t458, t450, t454
40 S 425 tex_result t425
41 S 435 E 425 fmul t435, t425, t11
41 S 459 E 435, E 455 fadd t459, t455, t435
40 S 428 tex_result t428
41 S 436 E 428 fmul t436, t428, t11
41 S 460 E 436, E 456 fadd t460, t456, t436
40 S 463 E 348, E 459 fadd t463, t348, t459
39 S 431 tex_result t431
40 S 437 E 431 fmul t437, t431, t11
40 S 434 tex_result t434
41 S 438 E 11, E 434 fmul t438, t434, t11
40 S 461 E 437, E 457 fadd t461, t457, t437
39 S 464 E 349, E 460 fadd t464, t349, t460
38 S 462 E 438, E 458 fadd t462, t458, t438
37 S 465 E 350, E 461 fadd t465, t350, t461
36 S 486 fmul t486, u140 (unif[1]), t463
37 S 490 fmul t490, u141 (unif[5]), t464
38 S 494 E 486, E 490 fadd t494, t486, t490
37 S 485 fmul t485, u142 (unif[0]), t463
38 S 489 fmul t489, u143 (unif[4]), t464
39 S 493 E 485, E 489 fadd t493, t485, t489
38 S 487 fmul t487, u144 (unif[2]), t463
39 S 491 fmul t491, u145 (unif[6]), t464
40 S 495 E 487, E 491 fadd t495, t487, t491
39 S 488 E 463 fmul t488, u146 (unif[3]), t463
39 S 492 E 464 fmul t492, u147 (unif[7]), t464
39 S 496 E 488, E 492 fadd t496, t488, t492
38 S 466 E 351, E 462 fadd t466, t351, t462
37 S 498 fmul t498, u148 (unif[9]), t465
38 S 502 E 494, E 498 fadd t502, t494, t498
37 S 497 fmul t497, u149 (unif[8]), t465
38 S 501 E 493, E 497 fadd t501, t493, t497
37 S 499 fmul t499, u150 (unif[10]), t465
38 S 503 E 495, E 499 fadd t503, t495, t499
37 S 500 E 465 fmul t500, u151 (unif[11]), t465
37 S 504 E 496, E 500 fadd t504, t496, t500
36 S 506 fmul t506, u152 (unif[13]), t466
37 S 510 E 502, E 506 fadd t510, t502, t506
36 S 505 fmul t505, u153 (unif[12]), t466
37 S 509 E 501, E 505 fadd t509, t501, t505
36 S 507 fmul t507, u154 (unif[14]), t466
37 S 511 E 503, E 507 fadd t511, t503, t507
36 S 508 E 466 fmul t508, u155 (unif[15]), t466
36 S 512 E 504, E 508 fadd t512, t504, t508
35 S 518 fmul t518, u156 (unif[21]), t510
36 S 514 fmul t514, u157 (unif[17]), t509
37 S 522 E 514, E 518 fadd t522, t514, t518
36 S 517 fmul t517, u158 (unif[20]), t510
37 S 513 fmul t513, u159 (unif[16]), t509
38 S 521 E 513, E 517 fadd t521, t513, t517
37 S 519 fmul t519, u160 (unif[22]), t510
38 S 515 fmul t515, u161 (unif[18]), t509
39 S 523 E 515, E 519 fadd t523, t515, t519
38 S 520 E 510 fmul t520, u162 (unif[23]), t510
38 S 516 E 509 fmul t516, u163 (unif[19]), t509
38 S 524 E 516, E 520 fadd t524, t516, t520
37 S 526 fmul t526, u164 (unif[25]), t511
38 S 530 E 522, E 526 fadd t530, t522, t526
37 S 525 fmul t525, u165 (unif[24]), t511
38 S 529 E 521, E 525 fadd t529, t521, t525
37 S 527 fmul t527, u166 (unif[26]), t511
38 S 531 E 523, E 527 fadd t531, t523, t527
37 S 528 E 511 fmul t528, u167 (unif[27]), t511
37 S 532 E 524, E 528 fadd t532, t524, t528
36 S 534 fmul t534, u168 (unif[29]), t512
37 S 538 E 530, E 534 fadd t538, t530, t534
36 S 533 fmul t533, u169 (unif[28]), t512
37 S 537 E 529, E 533 fadd t537, t529, t533
36 S 535 fmul t535, u170 (unif[30]), t512
37 S 539 E 531, E 535 fadd t539, t531, t535
36 S 536 E 512 fmul t536, u171 (unif[31]), t512
36 S 540 E 532, E 536 fadd t540, t532, t536
35 S 548 fmul t548, u172 (unif[39]), t538
36 S 544 fmul t544, u173 (unif[35]), t537
37 S 552 E 544, E 548 fadd t552, t544, t548
36 S 545 fmul t545, u174 (unif[36]), t538
37 S 541 fmul t541, u175 (unif[32]), t537
38 S 549 E 541, E 545 fadd t549, t541, t545
37 S 546 fmul t546, u176 (unif[37]), t538
38 S 542 fmul t542, u177 (unif[33]), t537
39 S 550 E 542, E 546 fadd t550, t542, t546
38 S 547 E 538 fmul t547, u178 (unif[38]), t538
38 S 543 E 537 fmul t543, u179 (unif[34]), t537
38 S 551 E 543, E 547 fadd t551, t543, t547
37 S 556 fmul t556, u180 (unif[43]), t539
38 S 560 E 552, E 556 fadd t560, t552, t556
37 S 553 fmul t553, u181 (unif[40]), t539
38 S 557 E 549, E 553 fadd t557, t549, t553
37 S 554 fmul t554, u182 (unif[41]), t539
38 S 558 E 550, E 554 fadd t558, t550, t554
37 S 555 E 539 fmul t555, u183 (unif[42]), t539
37 S 559 E 551, E 555 fadd t559, t551, t555
36 S 564 fmul t564, u184 (unif[47]), t540
37 S 568 E 560, E 564 fadd t568, t560, t564
36 S 561 fmul t561, u185 (unif[44]), t540
37 S 565 E 557, E 561 fadd t565, t557, t561
36 S 562 fmul t562, u186 (unif[45]), t540
37 S 578 rcp t578, t568
38 S 566 E 558, E 562 fadd t566, t558, t562
37 S 563 E 540 fmul t563, u187 (unif[46]), t540
37 S 567 E 559, E 563 fadd t567, t559, t563
36 S 579 E 568 fmul t579, t568, t578
36 S 580 E 579 fsub t580, 2.000000, t579
36 S 581 E 578, E 580 fmul t581, t578, t580
35 S 583 E 565 fmul t583, t565, u188 (vp_x_scale)
35 S 585 E 566 fmul t585, t566, u189 (vp_y_scale)
35 S 584 E 583 fmul t584, t583, t581
35 S 586 E 585 fmul t586, t585, t581
35 S 582 E 584 ftoi t582.16a, t584
35 E 586 ftoi t582.16b, t586
34 E 582 mov vpm, t582
33 S 587 E 567 fmul t587, t567, u190 (vp_z_scale)
33 S 588 E 587 fmul t588, t587, t581
33 E 588 fadd vpm, t588, u191 (vp_z_offset)
32 E 581 mov vpm, t581
31 E 6 mov vpm, t6
30 E 7 mov vpm, t7
29 E 367, E 479 fadd vpm, t367, t479
27 S 126 E 47 fmul t126, t47, t3
27 S 129 E 64 fmul t129, t64, t4
27 S 132 E 126, E 129 fadd t132, t126, t129
26 S 135 E 81 fmul t135, t81, t5
26 S 138 E 132, E 135 fadd t138, t132, t135
25 S 238 E 155 fmul t238, t155, t3
25 S 241 E 172 fmul t241, t172, t4
25 S 244 E 238, E 241 fadd t244, t238, t241
24 S 247 E 189 fmul t247, t189, t5
24 S 250 E 244, E 247 fadd t250, t244, t247
23 S 253 E 138, E 250 fadd t253, t138, t250
22 S 353 E 270 fmul t353, t270, t3
22 S 356 E 287 fmul t356, t287, t4
22 S 359 E 353, E 356 fadd t359, t353, t356
21 S 362 E 304 fmul t362, t304, t5
21 S 365 E 359, E 362 fadd t365, t359, t362
20 S 368 E 253, E 365 fadd t368, t253, t365
19 S 468 E 385 fmul t468, t385, t3
19 S 471 E 402 fmul t471, t402, t4
19 S 474 E 468, E 471 fadd t474, t468, t471
18 S 477 E 419 fmul t477, t419, t5
18 S 480 E 474, E 477 fadd t480, t474, t477
17 E 368, E 480 fadd vpm, t368, t480
15 S 127 E 48 fmul t127, t48, t3
15 S 130 E 65 fmul t130, t65, t4
15 S 133 E 127, E 130 fadd t133, t127, t130
14 S 136 E 82 fmul t136, t82, t5
14 S 139 E 133, E 136 fadd t139, t133, t136
13 S 239 E 156 fmul t239, t156, t3
13 S 242 E 173 fmul t242, t173, t4
13 S 245 E 239, E 242 fadd t245, t239, t242
12 S 248 E 190 fmul t248, t190, t5
12 S 251 E 245, E 248 fadd t251, t245, t248
11 S 254 E 139, E 251 fadd t254, t139, t251
10 S 354 E 271 fmul t354, t271, t3
10 S 357 E 288 fmul t357, t288, t4
10 S 360 E 354, E 357 fadd t360, t354, t357
9 S 363 E 305 fmul t363, t305, t5
9 S 366 E 360, E 363 fadd t366, t360, t363
8 S 369 E 254, E 366 fadd t369, t254, t366
7 S 469 E 3, E 386 fmul t469, t386, t3
6 S 472 E 4, E 403 fmul t472, t403, t4
5 S 475 E 469, E 472 fadd t475, t469, t472
4 S 478 E 5, E 420 fmul t478, t420, t5
3 S 481 E 475, E 478 fadd t481, t475, t478
2 E 369, E 481 fadd vpm, t369, t481
