Stencil buffer and depth buffer
Posted: Tue Oct 15, 2019 11:20 am
Hello! I built Qt libraries to work on drm/fkms. I tried to run applications that runs properly on any pi on the old gles2 driver on dispmanx, and I'm getting this:
Is this correct or maybe there is something wrong in my env/Qt build? Is there really no support on fkms for depth and stencil buffers?
Thanks.
EDIT: This is more precisely what Qt reports:
Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
QSGContext::initialize: depth buffer support missing, expect rendering errors
QSGContext::initialize: stencil buffer support missing, expect rendering errorsThanks.
qt.scenegraph.general: threaded render loop
qt.scenegraph.general: Using sg animation driver
qt.scenegraph.general: Animation Driver: using vsync: 16.67 ms
qt.scenegraph.general: texture atlas dimensions: 2048x2048
qt.scenegraph.general: R/G/B/A Buffers: 8 8 8 8
qt.scenegraph.general: Depth Buffer: 0
qt.scenegraph.general: Stencil Buffer: 0
qt.scenegraph.general: Samples: 0
qt.scenegraph.general: GL_VENDOR: Broadcom
qt.scenegraph.general: GL_RENDERER: VC4 V3D 2.1
qt.scenegraph.general: GL_VERSION: OpenGL ES 2.0 Mesa 19.2.0-rc1
qt.scenegraph.general: GL_EXTENSIONS: GL_AMD_performance_monitor GL_APPLE_texture_max_level GL_EXT_blend_minmax GL_EXT_compressed_ETC1_RGB8_sub_texture GL_EXT_discard_framebuffer GL_EXT_draw_buffers GL_EXT_draw_elements_base_vertex GL_EXT_frag_depth GL_EXT_map_buffer_range GL_EXT_multi_draw_arrays GL_EXT_occlusion_query_boolean GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_texture_border_clamp GL_EXT_texture_format_BGRA8888 GL_EXT_unpack_subimage GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_parallel_shader_compile GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_MESA_tile_raster_order GL_NV_draw_buffers GL_NV_fbo_color_attachments GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth_texture GL_OES_draw_elements_base_vertex GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_required_internalformat GL_OES_rgb8_rgba8 GL_OES_stencil8 GL_OES_surfaceless_context GL_OES_texture_3D GL_OES_texture_border_clamp GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float
qt.scenegraph.general: Max Texture Size: 2048
qt.scenegraph.general: Debug context: false
