rexsj
Opengles slideshow
Tue Dec 11, 2012 8:53 am
Hello........my doubt is......Can i update my textures on opengles??
Right now, I am displaying 3 png images.......but will it be possible to display next 3 images after some delay?
I have been trying to do this...........and i found no post related to this.
Please help.Thanks in advance
rexsj
Re: Opengles slideshow
Wed Dec 12, 2012 6:33 am
I dont know if my question is unclear.....
Do i have to use some add-on for running a slideshow on opengles? what are the options possible ?
i am using freeimage to load the png image and render it to the screen via opengles.
Now how do i show it in a sequence?
Any small help will be appreciated..........thanks
-rst-
Wed Dec 12, 2012 11:08 am
I am definitely not an expert in OpenGL, but could it be just this simple (pseudo code, as your dev language not mentioned):
main_func() {
  while more images {
    img1 = load_image()
    apply_image_to_texture1()
    img2 = load_image()
    apply_image_to_texture2()
    img2 = load_image()
    update_display()
    sleep(x seconds)
If you start from the hello_triangle example, could you just call the init_textures() in the beginning of the update_model() (or redraw_model()) to load the next set of images?
How does your code look like now?
Regards,
JP
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
rexsj
Thu Dec 13, 2012 8:21 am
Thats exactly what i was doing........but update dint work,
it was some problem with glLoadTexture function.now its working fine.
Thanks a lot :P
rexsj
Thu Dec 13, 2012 9:39 am
there is some strange problem ........that the power of 2 images distort on the screen, while non of power of two images work fine with the scaling function. Pls tell me whats going wrong!!!
PeterO
Thu Dec 13, 2012 10:31 am
rexsj wrote:there is some strange problem ........that the power of 2 images distort on the screen, while non of power of two images work fine with the scaling function. Pls tell me whats going wrong!!!
In what way are they "distorted" ?
PeterO
rexsj
Thu Dec 13, 2012 12:07 pm
I have attached the image
images distorted
PeterO
Thu Dec 13, 2012 6:18 pm
The circles look circular to me so I'm not sure what you mean by "distorted".
PeterO
rexsj
Fri Dec 14, 2012 5:12 am
rexsj wrote:I have attached the image
The original files attached
Orginal files
-rst-
Fri Dec 14, 2012 11:59 am
So you mean the 'backgrounds' you got in your screenshot are undesired artifacts?
rexsj
Sat Dec 15, 2012 8:04 am
ok, so these are only background distortions. can somebody help to solve this?
i tried using freeimage_setbackgroundcolor and istransparent functions......
rexsj
Sat Dec 15, 2012 1:06 pm
I used the composite function and it is working fine to give the white background for images...
thanks @rst for the help :)
Return to “OpenGLES”
