OpenGL EGL not working on Pi4??
Posted: Wed Aug 14, 2019 5:59 am
by kingbox1
Hi All
My programe is using OpenGL EGL, it works on pi3 and crashes on pi4 , it crashes at eglGetDisplay(EGL_DEFAULT_DISPLAY). I tried to build those sample code under /opt/vc which also uses EGL, however those applications output shows that it can not be run at pi4. So pi4 does not support EGL???
Re: OpenGL EGL not working on Pi4??
Posted: Wed Aug 14, 2019 8:31 am
by PeterO
This has been covered several times now...
This example got me going on the right track...
https://wiki.maemo.org/SimpleGL_example
PeterO
Posted: Sat Aug 17, 2019 3:19 am
by pjbesl444
Thank you very much for this pointer. Just what I was looking for.
Posted: Thu Jan 16, 2020 9:30 am
by aren2000
pjbesl444 wrote: ↑Sat Aug 17, 2019 3:19 am
Have you solved this problem? I looked at that example and copy to my project , but it still crashed at that location。btw, i use pi4
Posted: Thu Jan 16, 2020 10:04 am
by PeterO
I just recompiled the example on a Pi4 and it runs fine.
PeterO
Posted: Fri Jan 17, 2020 8:19 am
by aren2000
PeterO wrote: ↑Thu Jan 16, 2020 10:04 am
PeterO
thank u!
At last, I found out that I linked the wrong library file and it crashed
Posted: Fri Jan 17, 2020 8:25 am
by PeterO
Did you see tweet from Eben ?
https://twitter.com/EbenUpton/status/12 ... 6679391232
"@Raspberry_Pi 4 is now OpenGL ES 3.1 conformant. Thanks to all our friends at @thekhronosgroup
and @igalia for their help in getting this done."
PeterO
Posted: Fri Feb 07, 2020 10:50 pm
by rmills232
Did anyone manage to get this working on the Rpi 3, I'm having trouble with that.
