Faberix
Fragment shader per-pixel memory or color attachment
Sat Apr 29, 2017 12:34 pm
Hi
I am writing a real-time motion detection application for the raspberry pi and it's camera to test some algorithms. I have two algorighms in mind. One using a background color and mean absolute deviation per pixel (and some others; in total 4 per-pixel variables [3 uchars and 1 float, but I could use a 4th uchar instead of the float]), the other using a single-layer neural network (actually, it's a filter with a different 3*3 kernel for each pixel, so I would need 9 floats per pixel), both with a gray-scale input. I wanted to implement these using OpenGL ES (in a fragment shader drawing to an FBO), however, it seems to be quite complicated.
For better understanding, here are the essential parts my cpu-only implementation (using OpenCV mats) of the two algorithms:
The first algorithm:
class PixelHistory {
private:
	unsigned char backgroundColor;
	unsigned char currentColor;
	unsigned char currentColorCount = 0;
	float meanAbsoluteDeviation = 3.0f;
	unsigned char tolerance = 2*meanAbsoluteDeviation+1;
public:
	PixelHistory(unsigned char initColor) {
		backgroundColor = initColor;
		currentColor = initColor;
	PixelHistory() {
		currentColor = 0;
		backgroundColor = 0;
	void init(unsigned char initColor) {
	inline unsigned char getTolerance() {
		return tolerance;
	 * returns true if newColor != backgroundColor*/
	int update(unsigned char newColor/*, int tolerance*/);
int PixelHistory::update(unsigned char newColor) {
	tolerance = 2 * meanAbsoluteDeviation + 2;
	if (absDiff(backgroundColor, newColor) > tolerance) {
		if (absDiff(currentColor, newColor) > tolerance) {
			currentColor = newColor;
			currentColorCount = 1;
		} else {
			currentColorCount++;
		if (currentColorCount > historyTime * fps) {
			backgroundColor = currentColor;
		return 1;
	meanAbsoluteDeviation = meanAbsoluteDeviation * oldColorWeighting + absDiff(backgroundColor, newColor) * newColorWeighting;
	backgroundColor = backgroundColor + ((int) newColor - backgroundColor) * newColorWeighting;
	return 0;
For the neural-network-approach:
#include "Neuron.hpp"
using namespace std;
const float Neuron::NO_MOTION_VALUE = 1;
float* Neuron::defaultKernel = new float[kernelSize];
float Neuron::learningRate = 0.01;
float Neuron::minWeighting = 0.000001;
float Neuron::adjustThreshold = 0.01;
Neuron::Neuron(int x, int y, bool centerCoords) {
	if (centerCoords) {
		this->x = x - kernelSide / 2;
		this->y = y - kernelSide / 2;
	} else {
		this->x = x;
		this->y = y;
	int i = 0;
	for (int y1 = 0; y1 < kernelSide; y1++) {
		for (int x1 = 0; x1 < kernelSide; x1++) {
			weightings[x1][y1] = defaultKernel[i];
			i++;
Neuron::Neuron(int x, int y, float **weightings, bool centerCoords) {
	if (centerCoords) {
	} else {
		this->x = x;
		this->y = y;
			this->weightings[x][y] = weightings[x][y];
inline float Neuron::computeError(float output) {
	return NO_MOTION_VALUE - output;
void Neuron::initDefaultKernel() {
	float initValue = 1.0 / 128;
	for (int i = 0; i < kernelSize; i++) {
		defaultKernel[i] = initValue;
void Neuron::freeMemory() {
	delete[] defaultKernel;
float Neuron::computeOutput(const Mat &mat) {
	float output = 0;
	for (int tx = 0; tx < kernelSide; tx++) {
		for (int ty = 0; ty < kernelSide; ty++) {
			output += mat.at<unsigned char>(y + ty, x + tx) * weightings[tx][ty];
//	learn
	float error = computeError(output);
	if (abs(error) > adjustThreshold) {
				weightings[tx][ty] += learningRate * weightings[tx][ty] * error * mat.at<unsigned char>(y + ty, x + tx);
				if (weightings[tx][ty] <= 0) {
					weightings[tx][ty] = minWeighting;
	meanAbsoluteDeviation += (abs(error) - meanAbsoluteDeviation) * learningRate;
	return output;
I would need the variables mentioned above on the gpu only, so it would be useful to have some per-pixel-buffer I can read from and write to from the fragmentshader. I could bypass that in the first algorithm using a ARGB output and the first bit of the mean absolute deviation as an indicator if there is motion or not and then using the output as a texture. For the second algorithm, a bypass like that would definitly mean too much moving, besides (after what I have read), OpenGL ES 2 does not support additional channels or color attachments. What would be an option is writing to the FBO and directly reuse it in the fragment shader. Is that possible? I have found a promising extension (but haven't tested it yet) for OpenGL ES: https://www.khronos.org/registry/OpenGL ... uffers.txt.
Is there a way to use a per-pixel-memory (per-fragment-memory respectively) or any usable workaround?
I have a raspberry pi 2 model B.
Return to “OpenGLES”
