I am writing a real-time motion detection application for the raspberry pi and it's camera to test some algorithms. I have two algorighms in mind. One using a background color and mean absolute deviation per pixel (and some others; in total 4 per-pixel variables [3 uchars and 1 float, but I could use a 4th uchar instead of the float]), the other using a single-layer neural network (actually, it's a filter with a different 3*3 kernel for each pixel, so I would need 9 floats per pixel), both with a gray-scale input. I wanted to implement these using OpenGL ES (in a fragment shader drawing to an FBO), however, it seems to be quite complicated.
For better understanding, here are the essential parts my cpu-only implementation (using OpenCV mats) of the two algorithms:
The first algorithm:
class PixelHistory {
private:
unsigned char backgroundColor;
unsigned char currentColor;
unsigned char currentColorCount = 0;
float meanAbsoluteDeviation = 3.0f;
unsigned char tolerance = 2*meanAbsoluteDeviation+1;
public:
PixelHistory(unsigned char initColor) {
backgroundColor = initColor;
currentColor = initColor;
PixelHistory() {
currentColor = 0;
backgroundColor = 0;
void init(unsigned char initColor) {
inline unsigned char getTolerance() {
return tolerance;
* returns true if newColor != backgroundColor*/
int update(unsigned char newColor/*, int tolerance*/);
int PixelHistory::update(unsigned char newColor) {
tolerance = 2 * meanAbsoluteDeviation + 2;
if (absDiff(backgroundColor, newColor) > tolerance) {
if (absDiff(currentColor, newColor) > tolerance) {
currentColor = newColor;
currentColorCount = 1;
} else {
currentColorCount++;
if (currentColorCount > historyTime * fps) {
backgroundColor = currentColor;
return 1;
meanAbsoluteDeviation = meanAbsoluteDeviation * oldColorWeighting + absDiff(backgroundColor, newColor) * newColorWeighting;
backgroundColor = backgroundColor + ((int) newColor - backgroundColor) * newColorWeighting;
return 0;
}For the neural-network-approach:
#include "Neuron.hpp"
using namespace std;
const float Neuron::NO_MOTION_VALUE = 1;
float* Neuron::defaultKernel = new float[kernelSize];
float Neuron::learningRate = 0.01;
float Neuron::minWeighting = 0.000001;
float Neuron::adjustThreshold = 0.01;
Neuron::Neuron(int x, int y, bool centerCoords) {
if (centerCoords) {
this->x = x - kernelSide / 2;
this->y = y - kernelSide / 2;
} else {
this->x = x;
this->y = y;
int i = 0;
for (int y1 = 0; y1 < kernelSide; y1++) {
for (int x1 = 0; x1 < kernelSide; x1++) {
weightings[x1][y1] = defaultKernel[i];
i++;
Neuron::Neuron(int x, int y, float **weightings, bool centerCoords) {
if (centerCoords) {
} else {
this->x = x;
this->y = y;
this->weightings[x][y] = weightings[x][y];
inline float Neuron::computeError(float output) {
return NO_MOTION_VALUE - output;
void Neuron::initDefaultKernel() {
float initValue = 1.0 / 128;
for (int i = 0; i < kernelSize; i++) {
defaultKernel[i] = initValue;
void Neuron::freeMemory() {
delete[] defaultKernel;
float Neuron::computeOutput(const Mat &mat) {
float output = 0;
for (int tx = 0; tx < kernelSide; tx++) {
for (int ty = 0; ty < kernelSide; ty++) {
output += mat.at<unsigned char>(y + ty, x + tx) * weightings[tx][ty];
// learn
float error = computeError(output);
if (abs(error) > adjustThreshold) {
weightings[tx][ty] += learningRate * weightings[tx][ty] * error * mat.at<unsigned char>(y + ty, x + tx);
if (weightings[tx][ty] <= 0) {
weightings[tx][ty] = minWeighting;
meanAbsoluteDeviation += (abs(error) - meanAbsoluteDeviation) * learningRate;
return output;
}Is there a way to use a per-pixel-memory (per-fragment-memory respectively) or any usable workaround?
I have a raspberry pi 2 model B.
