kirgene
Can't render to render buffer
Sun Apr 23, 2017 1:09 pm
I'd like to do offscreen rendering and processing using render buffer and EGL_IMAGE_BRCM_VCSM:
    GLuint buffer = 0;
    m_gl_funcs->glGenRenderbuffers(1, &buffer);
    m_gl_funcs->glBindRenderbuffer(GL_RENDERBUFFER, buffer);
    m_vcsm_info->width = m_vcsm_info->height = 2048;
    EGLImageKHR eglFbImage = eglCreateImageKHR(egl_display, EGL_NO_CONTEXT,
            EGL_IMAGE_BRCM_VCSM, m_vcsm_info, NULL);
    assert(eglFbImage != EGL_NO_IMAGE_KHR && m_vcsm_info->vcsm_handle != 0);
    glEGLImageTargetRenderbufferStorageOES(GL_RENDERBUFFER, eglFbImage);
    assert(!glGetError());
but getting GL_INVALID_OPERATION error when using glEGLImageTargetRenderbufferStorageOES.
Is glEGLImageTargetRenderbufferStorageOES supported in Raspberry Pi ?
beddu
Re: Can't render to render buffer
Wed May 24, 2017 6:05 pm
Hi!
I managed to do rendering to texture in a slightly different way.
First of all generate a texture with the same format and dimensions as my viewport and no filtering:
glGenTextures(1, (GLuint*)&frameBufferTexture);
glBindTexture(GL_TEXTURE_2D, (GLuint)frameBufferTexture);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, viewportWidth, viewportHeight, 0, GL_RGBA, GL_UNSIGNED_BYTE, 0);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
Then I generate the frame buffer and bind the texture to it in this way:
glGenFramebuffers(1, &frameBufferHandle);
glBindFramebuffer(GL_FRAMEBUFFER, frameBufferHandle);
glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, (GLuint)frameBufferTexture,0);
glBindFramebuffer(GL_FRAMEBUFFER, 0);
Then I draw a square mesh with screen dimensions and map the texture to it. Selecting the buffer in this way:
//draw to the custom buffer
//draw the custom buffer as a textured mesh to the back-buffer
eglSwapBuffers(display, surface);
Hope it will be useful!
Return to “OpenGLES”
