I have an application that I want to run in a fixed aspect ratio regardless of native screen resolution. To do this I am specifying appropriate src/dest rectangles to vc_dispmanx_element_add so that there are gaps at the top and bottom of the screen. This works fine, however the underlying console is still visible in the gaps. Is there a way to disable the console plane or some other way to make the gaps blank?
Thanks,
Pete
