raysan5
Problem with GLSL shader (driver for unroll)
Fri Oct 14, 2016 9:42 am
I've got a problem with a shader I'm using internally on my library raylib (https://github.com/raysan5/raylib).
That shader is generic and computes lighting for up to 8 lights that can be omni, spot and directional. Shader works ok on most platforms (Windows, Linux, OSX, Android, HTML5) except on Raspberry Pi (I use a Raspberry Pi 1 Model B). Here it is my GLSL shader for reference: https://github.com/raysan5/raylib/blob/ ... tandard.fs
Shader just fails silently on my Pi, screens turns in white. No compile errors, no warnings.
After long investigation, it seems that shader fails due to the for-loop and branching, on my tests I got it working if I setup a specific lights number and type avoiding for-loop and branches... but I need it to be more generic.
Here it is a detailed explanation (last post): https://github.com/raysan5/raylib/issues/167
Could someone give me some tip/advice/help to solve this problem?
Many thanks! :)
paddyg
Re: Problem with GLSL shader (driver for unroll)
Mon Oct 24, 2016 7:10 pm
@raysan5 can't give very specific help but I have found that the impact of conditional sections is very severe on shader performance. In the end, with pi3d, I had a series of different shaders rather than a general one, where code overlaps I have split it into includible sections which are gathered together prior to compiling. Unfortunately that makes the code very difficult to read!
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
raysan5
Tue Oct 25, 2016 10:15 pm
Hi @paddyg, thank you very much for your answer! Just spoken with a couple of shader experts and all of them recommend me the same as you: avoid branches completely and generate multiple shaders instead of a general pourpose one. I will follow your recommendations. Thanks! :)
Return to “OpenGLES”
