Tweedledum
Arch Linux "failed to add service - already in use?"
Tue Aug 21, 2012 11:44 am
I've been working on getting DirectFB to work on the Pi for a couple of weeks. It works fine in software rendering, although it's slow, but when I try to enable EGL I get the message
[big number]: * failed to add service - already in use?
I get the same error message when I try to run the samples in '/opt/vc/src/hello_pi'. They all compile fine but none of them will run, all giving the error message above.
I've seen another post about a similar problem on Raspbian, but that was fixed with an OS update, unfortunately updating Arch has had no effect.
If anyone has any ideas I would appreciate it!
dom
Re: Arch Linux "failed to add service - already in use?"
Tue Aug 21, 2012 12:05 pm
What memory split are you running with? openGL requires the 128 or 192 splits.
Tweedledum
Tue Aug 21, 2012 12:17 pm
Brilliant! Thanks! I was using a smaller split, changed it and the error has gone!
pingaaas
Sun Jan 31, 2016 6:21 pm
How can I change the memory splits?
dom
Sun Jan 31, 2016 6:40 pm
pingaaas wrote:How can I change the memory splits?
Try gpu_mem=128 in config.txt (on boot partition).
If using raspbian you can run raspi-config.
pingaaas
Sun Jan 31, 2016 6:59 pm
Thanks! I have tried that. I am using buildroot. If I try any gpu_mem value different from 16, that raspberry pi does not boot. Do you know why this happens?
dom
Sun Jan 31, 2016 8:42 pm
pingaaas wrote:Thanks! I have tried that. I am using buildroot. If I try any gpu_mem value different from 16, that raspberry pi does not boot. Do you know why this happens?
gpu_mem=16 ises start_cd.elf/fixup_cd.dat. Higher values will use start.elf/fixup.dat.
Make sure start.elf/fixup.dat are present and correct.
pingaaas
Sun Jan 31, 2016 8:55 pm
That did it! Thank you so much!
juanluiscarpinteiro
Thu Oct 27, 2016 3:06 am
dom wrote:What memory split are you running with? openGL requires the 128 or 192 splits.
I tried both and i still cant run emulationstation. funny thing is i can run it through putty in my computer but not through the pi itself
Return to “OpenGLES”
