sighrax
GL driver just showing the loading square. Please help me.
Sat May 07, 2016 12:18 am
my rpi3 gl driver's wont work at all. I know the gl driver can work because I have seen it on youtube gaming but in my case this is the only thing it displays:
please help me.JPG (17.38 KiB) Viewed 4367 times
sorry for the flash
what is the configuration?
Rive
Re: gl driver and raspberry pi 3 healp me please
Sat May 07, 2016 12:51 am
Did you turn it on, and reset gpu mem, and download the utilities?
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install mesa-utils
Then;
Advanced options/GL Driver/Enable
sudo rasp-config
Finally after reboot, gpu mem will be 64, set it to something like 128 - 190 ( don't go any higher than 192 is my suggestion, or you may not boot):
menu/preferences/raspberry pi configuration/performance
Then reboot
Done.
DNPNWO
sighrax
Re: GL driver just showing the loading square. Please help m
Sun May 08, 2016 9:07 pm
it still shows the samething. Any Ideas? I did managed to get rid of the black borders when the gpu driver is off by disabling the overscan from the menu.
rovitotv
Wed May 18, 2016 1:51 am
I have the exact same problem!!! For my setup I have tried a external monitor in which case I get your results and I have tried the Raspberry Pi Display. With the Raspberry Pi Display I get a bunch of wavy lines. I have installed/updated mesa and enabled the OpenGL driver plus added RAM to the video. Any other ideas?
kusti8
Wed May 18, 2016 10:40 am
It's not guaranteed to work for everyone which is why it is still in alpha. To use it you need a new monitor. Also, it currently doesn't support the Pi Display
sighrax
Mon May 30, 2016 3:53 am
I fixed it by replacing all the files that are in the boot partition with new and un-updated ones from another installation, of a ''spare'' SD card(same OS; raspbian)
From the ''spare'' SD which has the 'untouched' raspbian installation, copy all the boot files including the overlay folder from the boot partition and paste them into the SD you want to use that GL driver which renders the squary screens such as the one I posted.
then problem solved!
Thanks for helping me, the help was great after all.
Return to “OpenGLES”
