abcdeef
vertex shader
Fri Feb 12, 2016 8:02 pm
i try to render a quad with MVP-Matrix and an offset:
    precision mediump float;
    uniform mat4 u_mvpMatrix;
    uniform vec2 u_offset;
    attribute vec4 a_position;
    attribute vec2 a_texCoord;
    varying vec2 v_texCoord;
    void main()
       gl_Position   =a_position;
       gl_Position.x-=u_offset.x;
       gl_Position  *=u_mvpMatrix;
       v_texCoord = a_texCoord;
run the opengl-code on X11 + SDL it looks right:
under raspberry pi2 without x the quad didn't apear.
but when i remove the MVP-Matrix multiplacation:
    void main()
       //gl_Position  *=u_mvpMatrix;
it looks so:
or without the offset
    void main()
       //gl_Position.x-=u_offset.x;
it looks:
why can't i use MVP-Matrix mulltiplication and offset together?
p.s.: my draw-function:
 glUseProgram ( userData->programObject );
  glUniformMatrix4fv( userData->mvpLoc, 1, GL_FALSE, (GLfloat*) &userData->mvpMatrix.m[0][0] );
  glUniform2f(userData->offsetLoc, 0.5, 0.0);
glVertexAttribPointer ( userData->positionLoc, 3, GL_FLOAT, GL_FALSE, 0, userData->vertices );
  glVertexAttribPointer ( userData->texCoordLoc, 2, GL_FLOAT, GL_FALSE, 0, userData->texCoord );
    glDrawArrays  ( GL_TRIANGLE_STRIP, 0, 4);
Return to “OpenGLES”
