corjan
Back buffer gets cleared?
Fri Sep 25, 2015 7:12 am
Currently I am porting a bit of openGL code to the raspberry.
To reduce the number of redraws, it won't redraw parts that haven't changed.
Here I have trouble with the raspberry somehow. It seems it is clearing the back buffer with every frame. So stuff I draw one frame is thrown away the next. When I let the openGL code draw everything every frame, all is fine (expect the performance :) ).
I created a small code snipplet to demonstrate this:
#include "lib_instrument.h"
#include <stdio.h>
int main(int argc, char* argv[])
	int i;
	int w = 1920;
	int h = 1080;
	int x = SDL_WINDOWPOS_CENTERED;
	int y = SDL_WINDOWPOS_CENTERED;
	SDL_Window* window = NULL;
	if (SDL_Init(SDL_INIT_VIDEO) != 0) {
		log_error("Main", "Unable to initialize SDL Video:  %s", SDL_GetError());
		return 1;
	window = SDL_CreateWindow("Air Panel", x, y, w, h, SDL_WINDOW_OPENGL);
	SDL_GL_CreateContext(window);
        printf("Drawing red\n");
	glClearColor(1.0f, 0.0f, 0.0f, 0.0f);
	glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
        // Screen will indeed become red, all is still fine
        for(int i=0; i < 10; i++) {
	    printf("Swap\n");
	    SDL_GL_SwapWindow(window);
            // Here the screen is black
            // I expect it to be black->red->black->red->black etc. here
	return 0;
Any help is appreciated,
Kind regards,
Corjan
PeterO
Re: Back buffer gets cleared?
Fri Sep 25, 2015 9:22 am
In my experience it is performing as expected, but then I've not tried to do what you are trying !
I've not used SDL either, so I don't know what "SDL_GL_SwapWindow(window);" actually does but the manual page for eglSwapBuffers here https://www.khronos.org/registry/egl/sd ... fers.xhtml suggests that
eglSurfaceAttrib https://www.khronos.org/registry/egl/sd ... trib.xhtml can be used to change the swap behaviour. I can't try it out at the moment (no access to a Pi).
PeterO
dave j
Fri Sep 25, 2015 9:23 am
Tile based GPUs don't preserve the back buffer by default because it reduces performance.
You can control it using EGL_SWAP_BEHAVIOUR (see here).
You should also read Performance Tuning for Tile Based Architectures which has a good explanation of why you should avoid it if possible and other performance hints for tile based GPUs.
PeterO
Fri Sep 25, 2015 9:24 am
SNAP ! :D
PeterO
dattrax
Wed Dec 16, 2015 7:09 pm
It's not really anything to do with tiled or immediate mode renderers, but more what the EGL speciation says when eglSwapbuffers is called.
From the specification -
The contents of ancillary buffers are always undefined after calling eglSwap-
Buffers. The contents of the color buffer are undefined if the value of the EGL_SWAP_BEHAVIOR attribute of surface is not EGL_BUFFER_PRESERVED. The value of EGL_SWAP_BEHAVIOR can be set for some surfaces using eglSurfaceAttrib, as described in section 3.5.619
Undefined can mean anything. In a immediate mode renderer it can be the frame from three swaps ago, in tiled it could be a default color, just you can't ever rely on it.
Return to “OpenGLES”
