GLBasic
libGLES_CM.so is missing
Mon Jul 02, 2012 9:13 pm
as said, we're using OpenGL|ES 1.1 and the library seems missing on the Ubuntu image. Anything I can do?
Breakthrough
Re: libGLES_CM.so is missing
Thu Aug 09, 2012 3:49 pm
I'm trying to port an SDL OpenGL application to OpenGL-ES, and ran into the same problem. I made sure I installed the proper packages, but the linker couldn't find libGLES_CM.
So, puzzled, I searched for all files starting with "libGL", and actually found that the library was infact present - just with a slightly different name: libGLESv1_CM.
Thus, for OpenGL ES v1.x, you link with the flag -lGLESv1_CM, and for v2.x, you link with the flag -lGLESv2.
Pickle
Thu Aug 09, 2012 5:39 pm
at least with the debian image everything was tucked away in /opt/vc
so /opt/vc/include has the headers and /opt/vc/lib has the libs
dom
Fri Aug 10, 2012 1:09 am
There is no GLES_CM. GLESv2 contains both GLES v1 and v2. Make sure you link with the hw accelerated libs (usually installed in /opt/vc/lib).
Chips
Sat Aug 25, 2012 5:54 pm
Then why not making a link by default from GLESv1_CM to GLESv2 ?
Many source code depends on this name so it would avoid to waste time on this issue...
dom
Sat Aug 25, 2012 6:04 pm
Does this:
cd /opt/vc/lib
sudo ln -s libGLESv2.so libGLES_CM.so
make building easier?
Chips
Fri Sep 07, 2012 6:23 pm
no, you're missing the v1
eg:
sudo ln -s libGLESv2.so libGLESv1_CM.so
dom
Fri Sep 07, 2012 10:03 pm
Chips wrote:no, you're missing the v1
eg:
Okay, so would doing:
make building easier? I can probably add that to the git repo, so you cat that link as standard.
Chips
Sat Sep 08, 2012 9:27 am
Yes, that would helps
Return to “OpenGLES”
