PeterO
Current "work in progress"
Fri Jan 31, 2020 10:48 pm
Finally got round to doing some stuff with Blender 2.81, including adding a texture for the "Computer On" lamp in the console.
How I have to "reintegrate" the code for drawing all the buttons !
PeterO
ejolson
Re: Current "work in progress"
Sat Feb 01, 2020 4:07 am
PeterO wrote: the "Computer On" lamp in the console.
What is that?
PeterO
Sat Feb 01, 2020 6:54 am
PeterO
Mon Feb 03, 2020 10:45 pm
All the buttons work :-)
PeterO
ejolson
Mon Feb 03, 2020 11:46 pm
PeterO
Can you spin it around in three-dimensional space with a mouse while the lights blink and a program runs on the Elliott 803 simulator?
PeterO
Tue Feb 04, 2020 7:59 am
PeterO
Yes it has "3D navigation" so you can Pan/Tilt/Zoom etc though that needs a bit of work as it seems counter intuitive compared to the navigation controls in Blender (which I'm using for all the 3D object design).
Currently the 6 status lamps are flashing in a predictable way as there is no underlying machine emulation yet. Integrating this into the existing 803 emulator will be easy, but first I need to add the operator's hands !
PeterO
PeterO
Wed Feb 12, 2020 8:51 pm
I've now got a pair on hands working. The picture above shows (with green crosses) the vertices I'm using to detect when the hands are touching. The line is being drawn between the two nearest vertices. Now I need to workout which are the most important vertices so I can reduce the number. Then I will have to decide what to do when they get too close. Since only one is "active" at a time I might try just raising the inactive one out of the way.
PeterO
PeterO
Thu Feb 13, 2020 8:00 am
https://twitter.com/PeterOnion/status/1 ... 3142768640
Crude "collision avoidance" implemented :-)
PeterO
Return to “OpenGLES”
