bluenic
How to rotate graphics at any angle?
Sat Nov 01, 2014 6:58 pm
I'm searching for a method, to rotate graphics by a deliberate angle, or, at least, printing text to the screen at an angle of my choice. Preferably in Python, but C won't hurt too much, if there's no other option.
To give an example of what I intend to do, have a look at this stunning project http://www.youtube.com/watch?v=EFukhFujWuY
Unfortunately, the author seems to be unreachable. On his project page http://amrhein.eu/Radio2 he claims having used SDL for the UI, but I can't find any method to do a smooth rotation.
I would greatly appreciate any help on this.
Many thanks in advance, Klaus
mahjongg
Re: How to rotate graphics at any angle?
Sat Nov 01, 2014 8:52 pm
if you are talking about bit map graphics, it a question of a large array transformation, from a source image to a destination image, in the course of it a large bit of image information will get lost, so you must keep the original image if you want to do another angle. Algorithms do do the array transformation are probably just a google search away.
If you are talking about vector graphics, matters are much simpler, text is mostly vector graphics.
https://en.wikipedia.org/wiki/Rotation_(mathematics)
gordon77
Sat Nov 01, 2014 9:31 pm
bluenic wrote:Hi,
Any use?
http://stackoverflow.com/questions/2454 ... ythons-pil
Or
http://stackoverflow.com/questions/1327 ... ooth-edges
bluenic
Sun Nov 02, 2014 6:37 am
Many thanks to both of you for taking the trouble!
You put me on the right way. Though using pygame myself, I wasn't aware of the rotate function, and of the existance of the PIL neither. Must have had a serious blackout or was too much stuck with the SDL mentioned in the project.
Thanks again, Klaus.
PeterO
Sun Nov 02, 2014 7:50 am
You could use the GPU via openGL ES to do all the hard stuff.
1) Render the bitmap font into a texture
2) Load texture into GPU.
3) Load a vertex shader that will transform the area of the texture containing a letter into a position along the curve for the tuning dial.
3)For each letter to be displayed use the shader to render it into the correct position.
4) Read back completed image from gpu into cpu and then output the pixels to a small LCD.
PeterO
toxibunny
Sun Nov 02, 2014 9:51 am
what would you do if there wasn't enough space on a circle to fit all the channels?
note: I may or may not know what I'm talking about...
bluenic
Sun Nov 02, 2014 10:56 am
toxibunny wrote:what would you do if there wasn't enough space on a circle to fit all the channels?
Yes, I already thought this issue certainly would come up.
I think, I would update the invisible part of the disc accordingly on the fly, so while turning the knob the next channel will show up, regardless how many there are in the queue.
PeterO
Sun Nov 02, 2014 11:27 am
It's not a real dial bluenic is making, so all that matters is that the stations appear in the right order when the knob is turned either way.
PeterO
dividuum
Sun Nov 02, 2014 10:23 pm
I just threw together a quick proof of concept based on my tool info-beamer. I put the source code for the analog dial on github.
To use it, first get info-beamer for the pi then put the analog-dial source into any directory and run info-beamer inside this directory:
[email protected]:/path/to/analog-dial $ info-beamer .
This should create a visualization similar to the one you asked for. To control it, use the script I included:
[email protected]:/path/to/analog-dial $ ./set_item 0.5
The value is an (float) index into the list of items defined in items.json. So 0.5 centers on the first item in the list. The script simply sends control commands to info-beamer using UDP, so you can use any programming language you like to do this. I just wrote a blog post about this subject if you want to learn more.
Enjoy.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
blackshard83
Mon Nov 03, 2014 10:12 am
PeterO wrote:You could use the GPU via openGL ES to do all the hard stuff.
PeterO
You could use OpenVG instead of OpenGL ES, as long as you just need 2D graphics. OpenVG both handle bitmap and vector fonts and various basic transformations like rotation, scaling, translation, shearing, etc...
OpenVG anyway doesn't renders the TTF font into bitmap/vector glyphs. In a nutsheel you have to render the glyphs using an external library (freetype2 is the most viable option), then load the bitmap or vector path in GPU memory and blit using OpenVG.
Maybe other graphic libraries, like SDL, already offers a simpler way to do this without bothering with glyph rendering and loading, which is indeed a way to learn how fonts work.
paddyg
Thu Nov 06, 2014 5:12 pm
You've probably solved this one way or the other, but for the record this is a bare bones python version using pi3d
import pi3d
DISPLAY = pi3d.Display.create()
CAMERA = pi3d.Camera(is_3d=False)
myshader = pi3d.Shader('uv_flat')
myfont = pi3d.Font('fonts/FreeMonoBoldOblique.ttf')
mystring = pi3d.String(camera=CAMERA, font=myfont, is_3d=False, string='Rotating')
mystring.set_shader(myshader)
while DISPLAY.loop_running():
  mystring.draw()
  mystring.rotateIncZ(1)
ajstarks
Fri Dec 05, 2014 2:15 am
My OpenVG library may work for you: https://github.com/ajstarks/openvg (see the rotated text image in the README.
