ZARk
SDL2 Alpha Blending
Mon Oct 27, 2014 8:30 pm
Hello
Is anyone having issues with alpha blending a texture in SDL2 ?
SDL_SetTextureAlphaMod does not return an error.
But it simply doesn't work on screen.
(trying to crossfade two images for a simple slideshow)
HOWEVER, the same code works fine if i force to SOFTWARE renderer. (except it's horribly slow obviously)
I've converted the surface to 32bit RGBa, even using the same PixelFormat as the renderer... but no cigar.
any hints ? ideas ?
ZARk
Re: SDL2 Alpha Blending
Mon Oct 27, 2014 11:35 pm
I'm going to answer myself.
After testing a SDL2 alpha blending example on the net (which worked)
I managed finding the thing that didn't work .
Basically you NEED to ClearScreen , draw backgroundTexture, then on top modulate the alpha for the new texture.
what i did, was
fade in texture 1
fade in texture 2 etc...
What happened was that once i drew texture2 with opacity 0, the screen went black, instead of drawing on top of the previous buffer.
Somehow in SoftwareMode that worked.
Return to “Graphics programming”
