Hi everyone...
I'm playing around with coding and stuff. The project i am trying to use my Pi for doesn't need to boot all the way into LXDE really..
So I thought a simple interface like shown in the image would do me fine...
In the old days of pascal with DOS this was easy can anyone suggestion what to use to create a screen like this with the RasPi please?
Simple interfaces without xwindows
- Attachments
- install14.PNG (20.41 KiB) Viewed 11133 times
Re: Simple interfaces without xwindows
Ncurses should do the trick: http://en.wikipedia.org/wiki/Ncurses
something like 'apt-get libncurses-dev' should install the header files, you need to do 'apt-cache search ncurses' to find the actual package names. I have seen mention of python/ruby bindings too ...
Thank you very much. That looks like it will do exactly what I want.
Should be a nice little challenge to learn it too. thanks again for your help
check out dialog & cdk (& ncurses) http://invisible-island.net/dialog/dialog.html
With Free Pascal you can do things similar to what you did with Turbo Pascal. I have a number of minimal distributions of Free Pascal that make it *very* easy to try things. See this new message:
http://www.raspberrypi.org/phpBB3/viewt ... 971#p93971
- gordon@drogon.net
- Contact: Website Twitter
If you want simple graphics, of the old style where you poke pixels into a framebuffer, then look at the SDL libraries. That's more or less what you get with SDL. There are point plotting and line drawing libraries, but sometimes you just want to poke pixels
My BASIC interpreter uses SDL extensively and runs well on the console. Great to do simple graphics, etc. in (fun too if you like that sort of thing!)
-Gordon
-Gordon
Try this for fun, on your PI
cat >tryme.sh <<EOF
black='\033[30m'
red='\e[0;31m'
greenbg='\033[42m'
NC='\e[0m' # No Color
clear
tput cup 10 10
echo -e "${red}Raspberry ${greenbg}${black}PI${NC}"
tput cup 20 0
EOF
. ./tryme.sh
rm ./tryme.sh
Also fun,
P.S. Is anyone interested in this?
sudo apt-get install caca-utils
cacafire
Haha - cacafire even worked well inside a remote ssh terminal (putty) !
Not sure I'll ever use it again though.
That's the idea,Haha - cacafire even worked well inside a remote ssh terminal (putty) !
Supprisingly impressive over wifi ssh session using ConnectBot on an Andriod device.
Works whatever size you set the size of the terminal to on ConnectBot
There's not a great deal of point in cacafire in its self other than to demonstrate what can be done without XWindows/vnc both of which I think are a bit heavy for simple Raspberry projects.
