Yharooer
Creating a GUI without X?
Sat Sep 21, 2013 11:30 am
Sorry, this is probably in the wrong place. I guess this isn't technically "graphics programming" but it kinda is...
I know there are many programs that create a "GUI" like raspi-config (ok, not exactly a GUI), and many emulators run from the text thing (is it called shell or bash?) and I'm pretty sure these don't use X.
So what software/how would I be able to create a simple GUI? Something like raspi-config would be OK, but a full GUI would be better. I want it so I select one option, it does apt-get update && apt-get upgrade or something like that.
And if I'm in the wrong section, I would be grateful if someone could move this post to the correct one. Thanks!
joan
Re: Creating a GUI without X?
Sat Sep 21, 2013 11:48 am
I think raspi-config uses the whiptail package.
Yharooer
Sat Sep 21, 2013 11:56 am
Thanks, I'll take a look later.
Do you know if the options in Whiptail can change? ie. search a certain directory and create a new menu option for each file.
joan
Sat Sep 21, 2013 12:07 pm
Yharooer wrote:Thanks, I'll take a look later.
Sorry, never used it myself, I don't know.
DeeJay
Sat Sep 21, 2013 12:10 pm
Whiptail is just a text-based graphical interface to a shell script. If the shell (bash) can be programmed to do it, you can ask whiptail to display it.
Yharooer
Sat Sep 21, 2013 12:17 pm
Ok, thanks. I'll take a look.
Thaddy
Thu Sep 26, 2013 11:28 am
Freepascal can do this using f.e. the TurboVision framework. (fbdev)
An example is the fp development environment.
mikerr
Thu Sep 26, 2013 12:01 pm
Not directly, but I needed to do that in my version of raspi-config (set wifi settings - not integrated into main release yet):
http://github.com/mikerr/raspi-config (lines 588-601)
What it does is write those options to a tempfile which is in the form of a shell script, and executes that file.
DaveDriesen
Thu Sep 26, 2013 1:17 pm
Curses for text-mode UI
Framebuffer SDL for graphical UI (obviously more complicated)
Dave Driesen
Linux dev and oldskool elite
