Can you provide why it fails? Any information by start from console?
I have checked LibreElec and it looks like it uses fkms overlay so I think dispmanx_vnc should work. (I dont't have RPI4 to test)
- hanzelpeter
Re: Dispmanx VNC Server
It is not that it deosn't work at all. It just doesn't work on higher resolutions. Downsampling and option to specify resolution in config (what is possible with realvnc) would solve the problem.
I will do some testing and provide you with error.
I gave up on Dispmanx, as I cannot configure resolution, it can be done in /boot/config what I don't want.
Is there any other screen capture vnc server where you can specify resolution as parameter when you start the server? Also that can handle 4k?
