cary
How to draw nonconvex polygon in raspberry
Mon Apr 08, 2013 4:27 pm
Now i want to draw non-convex polygon on my raspberry.
I used to use GLUtesselator to do the drawing On my pc and i am a new guy to used opengl es. Does raspberry also support that?
Does any one know how to do this?
-rst-
Re: How to draw nonconvex polygon in raspberry
Tue Apr 09, 2013 4:14 pm
Maybe some of these would work on RPi http://stackoverflow.com/questions/3231 ... tesselator
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
cary
Wed Apr 10, 2013 3:49 am
Does raspberry support glu/glut? I only know raspberry support opengl es.
-rst-
Wed Apr 10, 2013 1:18 pm
No GLU - wiki says "GLU is not implemented in the embedded version of the OpenGL package, OpenGL ES." http://en.wikipedia.org/wiki/OpenGL_Utility_Library
Some mention of GLUT for RPi here http://www.raspberrypi.org/phpBB3/viewt ... UT#p127216
Thaddy
Fri May 10, 2013 12:22 pm
Just for drawing polygons have a look at openvg. ajstarks has a nice lib for it
raspteam
Mon Jan 13, 2014 6:00 am
I had be able to integrate opengl_es on my custom cross-compiler and to generate hello examples. That worked fine on wheesy. I would to compile glus or gtk in order to make a static library for my custom compiler.
I had a linker error during example link because i have not compiled gluraspberry_es.c source file. However, i have also an error during glu static library compilation. Anyone have met this problem? Have You a solution?
Return to “Graphics programming”
