hjimbens
MMal saying "unhandled 128"
Tue Nov 12, 2019 3:21 pm
Some videos when played with mmal produce a lot of "unhandled 128" lines on stdout. What does it mean? Which library is producing this output?
6by9
Re: MMal saying "unhandled 128"
Tue Nov 12, 2019 4:57 pm
MMAL is not an application, and can't play anything by itself.
So what application are you using as the basis of your media player? That might give us a chance to guess as to what is producing the message.
There is no error message from the MMAL library itself of the form that you quote.
dividuum
Tue Nov 12, 2019 6:19 pm
I've also noticed these errors and I'm pretty sure that error is from Mesa 3D. I think somewhere shader related. But I cannot find that code using the github search UI only at the moment.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
dividuum
Tue Nov 12, 2019 6:44 pm
hjimbens
Wed Nov 13, 2019 8:16 am
dividuum wrote: Should be this one:
https://github.com/mesa3d/mesa/blob/cac ... gram.h#L96
Thank you very much. I grepped through all .so files but I could not find the source of the string. I grepped through the kernels in /boot and the only candidate string was in kernel8.img while I am using the 32 bit kernel.
6by9 wrote: MMAL is not an application, and can't play anything by itself.
When I build the x11 branch of https://github.com/6by9/drm_mmal and run it with
./mmal-demo /opt/vc/src/hello_pi/hello_video/test.h264
I get the same "unhandled 128" output.
kilograham
Thu Oct 29, 2020 11:00 pm
I believe the latest mesa included in raspberry pi os (32 bit at least) should fix this issue (mesa bug)
kilograham
Fri Oct 30, 2020 6:47 pm
or more accurately should remove it from being outputted when the format is handled!
Return to “Graphics programming”
