MMal saying "unhandled 128"
Some videos when played with mmal produce a lot of "unhandled 128" lines on stdout. What does it mean? Which library is producing this output?
- Raspberry Pi Engineer & Forum Moderator
- Location: ZZ9 Plural Z Alpha, aka just outside Cambridge.
Re: MMal saying "unhandled 128"
MMAL is not an application, and can't play anything by itself.
So what application are you using as the basis of your media player? That might give us a chance to guess as to what is producing the message.
There is no error message from the MMAL library itself of the form that you quote.
I've also noticed these errors and I'm pretty sure that error is from Mesa 3D. I think somewhere shader related. But I cannot find that code using the github search UI only at the moment.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
Thank you very much. I grepped through all .so files but I could not find the source of the string. I grepped through the kernels in /boot and the only candidate string was in kernel8.img while I am using the 32 bit kernel.
When I build the x11 branch of https://github.com/6by9/drm_mmal and run it with6by9 wrote: MMAL is not an application, and can't play anything by itself.
./mmal-demo /opt/vc/src/hello_pi/hello_video/test.h264
I believe the latest mesa included in raspberry pi os (32 bit at least) should fix this issue (mesa bug)
or more accurately should remove it from being outputted when the format is handled!
