paulslocum
Help grabbing Omxplayer video frames using OMX.broadcom.video_splitter
Mon Aug 05, 2019 9:20 am
I was able to successfully tunnel a "video_splitter" component into Omxplayer's components between the video scheduler and renderer, and I set up a "FillBufferDone" callback on an unused video_splitter output port, but I don't understand the data I'm getting back.
The size of the buffer corresponds to the video's resolution, and the information in the buffer appears to correspond to color information in the video, but it's only giving me 1382400 bytes for a 1280x720 video -- that's 1.5 bytes per pixel. I was expecting 24 bit YUV, and I thought that only the "resizer" component could change formats, so I'd appreciate any additional info that anyone has about what's going on here.
Re: Help grabbing Omxplayer video frames using OMX.broadcom.video_splitter
Mon Aug 05, 2019 9:31 am
You are getting YUV420, with the U and V channels 'compressed'. Google will find the spec for it.
6by9
Mon Aug 05, 2019 10:54 am
Chroma subsampling is the phrase that James was looking for.
https://en.wikipedia.org/wiki/Chroma_subsampling#4:2:0
Mon Aug 05, 2019 10:55 am
Yup. It's a sort of compression.....!
paulslocum
Mon Aug 05, 2019 12:14 pm
Thanks, I appreciate the quick response! Is this the correct data format at this link:
https://en.wikipedia.org/wiki/YUV#Y%E2% ... conversion
Pasted from the article:
size.total = size.width * size.height;
y = yuv[position.y * size.width + position.x];
u = yuv[(position.y / 2) * (size.width / 2) + (position.x / 2) + size.total];
v = yuv[(position.y / 2) * (size.width / 2) + (position.x / 2) + size.total + (size.total / 4)];
rgb = Y′UV420toRGB888(y, u, v);
dom
Mon Aug 05, 2019 1:05 pm
That is the correct layout.
Note, it only works for nicely aligned size.width, size.height (multiples of 16 or 32). 1280x720 should be okay.
Otherwise you need to use aligned_width and aligned_height from component in the formula and treat width and height as crop values
(pixels between width and aligned_width are padding).
