Strange segfault after several hours of running program
Posted: Mon Jul 22, 2019 9:01 pm
Hi all, I created a program fairly closely related to hello_pi/hello_video.c. And for some reason after several hours of running the program I get these very strange segfaults that I cannot for the life of me figure out how to resolve. Here is what I am running:
- Raspberry PI 3B+
- Raspbian Lite (Buster)
I have checked the following:
- I am not under voltage. I am using a 5.1v 2.5a power supply from raspberry PI themselves.
- I did not over clock the system. I am sitting at 1.4 like a normal PI.
- The system has heat sinks and a fan to keep the temperature low.
- The system is also totally up to date (apt update... upgrade... rpi-update etc)
Here are a few of the errors I am receiving from the address sanitizer built into gcc:
Here is the output from gdb during those crashes:
All the crashes seem to be related to "completion_thread()". I have no idea what that is.
Any help would be greatly appreciated!
- Raspberry PI 3B+
==26987==ERROR: AddressSanitizer: heap-buffer-overflow on address 0x45009021 at pc 0x769ca548 bp 0x5a7fa474 sp 0x5a7fa040
READ of size 8 at 0x45009021 thread T450 (ILCS_HOST)
#0 0x769ca547 (/usr/lib/arm-linux-gnueabihf/libasan.so.5+0x3a547)
Address 0x45009021 is a wild pointer.
SUMMARY: AddressSanitizer: heap-buffer-overflow (/usr/lib/arm-linux-gnueabihf/libasan.so.5+0x3a547)
Shadow bytes around the buggy address:
0x28a011b0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x28a011c0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x28a011d0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x28a011e0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x28a011f0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
=>0x28a01200: fa fa fa fa[fa]fa fa fa fa fa fa fa fa fa fa fa
0x28a01210: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x28a01220: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x28a01230: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x28a01240: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x28a01250: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
Shadow byte legend (one shadow byte represents 8 application bytes):
Addressable: 00
Partially addressable: 01 02 03 04 05 06 07
Heap left redzone: fa
Freed heap region: fd
Stack left redzone: f1
Stack mid redzone: f2
Stack right redzone: f3
Stack after return: f5
Stack use after scope: f8
Global redzone: f9
Global init order: f6
Poisoned by user: f7
Container overflow: fc
Array cookie: ac
Intra object redzone: bb
ASan internal: fe
Left alloca redzone: ca
Right alloca redzone: cb
Thread T450 (ILCS_HOST) created by T443 here:
#0 0x769db9c7 in pthread_create (/usr/lib/arm-linux-gnueabihf/libasan.so.5+0x4b9c7)
#1 0x7693b203 in vcos_thread_create /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:212
Thread T443 created by T0 here:
#1 0x74ee1c57 in std::thread::_M_start_thread(std::unique_ptr<std::thread::_State, std::default_delete<std::thread::_State> >, void (*)()) (/usr/lib/arm-linux-gnueabihf/libstdc++.so.6+0x9dc57)
#2 0x6bb02a7f (<unknown module>)
==26987==ABORTING
==23420==ERROR: AddressSanitizer: SEGV on unknown address 0x0019c2c0 (pc 0x74b060f0 bp 0x74b08f3c sp 0x6acfe3b8 T2)
==23420==The signal is caused by a READ memory access.
#0 0x74b060ef in completion_thread (/opt/vc/lib/libvchiq_arm.so+0x20ef)
AddressSanitizer can not provide additional info.
SUMMARY: AddressSanitizer: SEGV (/opt/vc/lib/libvchiq_arm.so+0x20ef) in completion_thread
Thread T2 (VCHIQ completio) created by T0 here:
#0 0x769609c7 in pthread_create (/usr/lib/arm-linux-gnueabihf/libasan.so.5+0x4b9c7)
#1 0x768c0203 in vcos_thread_create /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:212
==23420==ABORTING
Thread 3 "VCHIQ completio" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x6fbfeb00 (LWP 15664)]
0x751c60f0 in completion_thread () from /opt/vc/lib/libvchiq_arm.so
