Pindrought
OpenGL - Does Stencil buffer not work on Raspberry Pi 3B+?
Mon Jul 22, 2019 4:51 pm
Edit: Solved.
I am using freeglut. When initializing my OpenGL context, I was not passing the GLUT_STENCIL flag. The stencil is working as expected now.
glClear(GL_STENCIL_BUFFER_BIT);
glEnable(GL_STENCIL_TEST);
glStencilMask(0x00); // don't write to stencil buffer
glStencilOp(GL_KEEP, GL_KEEP, GL_KEEP);
glStencilFunc(GL_EQUAL, 0, 0xFF);
pitchLines.Render();
With
and
glStencilFunc(GL_EQUAL, 1, 0xFF);
I am getting the same results. The sprite is still being rendered. My code works as expected on windows, but on the raspberry pi it seems like the stencil function is just ignored.
Any idea what gives? Is there something i'm missing that I need to do before using the stencil buffer on the PI?
Even tested with
glStencilFunc(GL_NEVER, 0, 0xFF);
and it still renders.
