AllenBarnett
Transparency in an 8BPP dispmanx resource
Thu Apr 04, 2019 12:07 am
Is it possible to make transparent pixels in a dispmanx resource with a type of VC_IMAGE_8BPP? The palette seems to be defined as an array of RGB565 colors. Is it possible to include an alpha value other than on the whole dispmanx element?
I'm trying to draw a non-square image in one dispmanx layer on top of another image in a lower layer.
Thanks,
Allen
6by9
Re: Transparency in an 8BPP dispmanx resource
Thu Apr 04, 2019 1:45 pm
If using Dispmanx (NOT the mailbox calls), then you can pass either RGB565 or RGBA32 entries. The firmware switches on the length of the write being either
16 * sizeof(uint32_t) and VC_IMAGE_4BPP, or 256 * sizeof(uint32_t) and VC_IMAGE_8BPP to be RGBA32
or
16 * sizeof(uint16_t) and VC_IMAGE_4BPP, or 256 * sizeof(uint16_t) and VC_IMAGE_8BPP to be RGB565.
AllenBarnett
Fri Apr 05, 2019 1:16 am
That works great! And sneaky, too! Thanks so much.
The color of my overlay don't look exactly like I would expect. Is it possible that the 32-bit palette format is BGRA?
