Gavinmc42
OpenGL tests
Tue Dec 18, 2018 11:58 am
I have been using Gentoo64 on Pi3B+'s which is using Eric's OpenGL driver.
Most of the Mesa3D demos seem to run.
ftp://ftp.freedesktop.org/pub/mesa/demos/
Comparing Browsers running WebGL was interesting.
Gentoo64 is now good enough to run Firefox and Chromium at the same time.
viewtopic.php?f=63&t=208314&start=250
Benchmarking Browsers does not benchmark OpenGL.
The Mesa demos come with an objviewer :D
Once the missing alpine skybox images are googled and found you end up with a rotating bunny image floating in mountains.
Celeron core duo 60fps, Gentoo64 25fps.
Swapping the GreatLakesBiplaneHP for the bunny starts to chug the PC - 37fps.
But it does horrible things to Gentoo64, fell over the bleeding edge of current Pi capability ;)
So too many vertices 142305, triangles 283266... is the limit 65K?
Testing utilities :D
https://www.mesa3d.org/utilities.html
llvmpipe - uses LLVM for x86 JIT code generation and is multi-threaded
https://www.mesa3d.org/systems.html
I think I saw something about LLVM JIT compiling in the WebGL stuff for Chromium, is that one of the tricks used for WebGL speed on x86?
I'm dancing on Rainbows.
Gavinmc42
Re: OpenGL tests
Sat Dec 29, 2018 8:50 am
Trying to test OpenGL on Raspbian.
Got latest 4.14 lite desktop version of Raspbian and glxgears was very jittery.
Thought I would try 4.19 kernel, did sudo BRANCH=next raspi-update
Enabled OpenGL via raspi-config after it booted, rebooted and got black screen on boot.
Is there a new trick for OpenGL driver enabling or does raspi-config break it?
Gavinmc42
Re: OpenGL tests
Mon Jul 22, 2019 9:07 am
Some missing dependencies but lots of the mesa demos are now compiling and working on a Pi4.
The ipers demo is pushing the Pi4.
Think I have found a new benchmark/stress test.
Wonder how it compares to the 3B+?
Gavinmc42
Re: OpenGL tests
Sat Jul 27, 2019 11:54 am
A bunch of errors making the objviewer :(
Was hoping it would just work so I could benchmark this Pi4.
With the 3B+ at 25fps I was hoping the Pi4 would do 60fps.
Can I port the objviewer code to Pascal?
Gavinmc42
Re: OpenGL tests
Sat Jul 27, 2019 12:13 pm
The demo just worked on a Pi4 :o
http://www.geeks3d.com/geexlab/downloads/
There is enough here to keep me busy for a long time :D
The shadertoy demo slows to 31fps at my full screen window 1280 x 960
Gavinmc42
Re: OpenGL tests
Sun Jul 28, 2019 8:32 am
Wings3D just installed and works.
It could import the mesa demo obj viewer bunny ;)
Time to start modelling stuff for game content.
This Pi4 get more useful everyday.
Gavinmc42
Re: OpenGL tests
Sat Aug 31, 2019 10:59 am
Openscenegraph is working on Gentoo64 :D
This is the oscviewer running 60fps, the fire and smoke is animated.
Openscenegraph is a prerequisite for Flightgear.
Flightgear is becoming a real pain to compile on an Gentoo64 aarch64 Pi4.
FG is probably the biggest stress test I can think of for the Pi4.
But there are other uses for Openscenegraph.
http://www.openscenegraph.org/index.php ... /use-cases
Unity and Unreal etc are used for stuff like this, not just games.
But they don't run on Pi's.
There is a Vulkanscenegraph so I imagine learning Openscenegraph will help with learning Vulkanscenegraph if it one day makes it to Pi's.
More learning on Pi's.
