Thank you, with a non progressive jpeg it works.
Now I missing last step.
But it shows a grey square with black lines.
Copyright (c) 2018 Raspberry Pi (Trading) Ltd
Decodes a JPEG image into a memory buffer.
#include <errno.h>
#include <fcntl.h>
#include <math.h>
#include <poll.h>
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
#include <sys/ioctl.h>
#include <sys/mman.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <unistd.h>
//#include <interface/vcsm/user-vcsm.h>
#include "bcm_host.h"
#include "interface/mmal/mmal.h"
#include "interface/mmal/util/mmal_default_components.h"
#include "interface/mmal/util/mmal_util_params.h"
#include "interface/mmal/util/mmal_util.h"
#include "interface/mmal/util/mmal_connection.h"
#include "interface/mmal/mmal_queue.h"
#include "interface/vcos/vcos.h"
#define MAX_BUFFERS 2
static inline int warn(const char *file, int line, const char *fmt, ...)
int errsv = errno;
va_list va;
va_start(va, fmt);
fprintf(stderr, "WARN(%s:%d): ", file, line);
vfprintf(stderr, fmt, va);
va_end(va);
errno = errsv;
return 1;
#define CHECK_CONDITION(cond, ...) \
do { \
if (cond) { \
int errsv = errno; \
fprintf(stderr, "ERROR(%s:%d) : ", \
__FILE__, __LINE__); \
errno = errsv; \
fprintf(stderr, __VA_ARGS__); \
abort(); \
} while(0)
#define WARN_ON(cond, ...) \
((cond) ? warn(__FILE__, __LINE__, __VA_ARGS__) : 0)
#define ERRSTR strerror(errno)
#define CHECK_STATUS(status, ...) WARN_ON(status != MMAL_SUCCESS, __VA_ARGS__); \
if (status != MMAL_SUCCESS) goto error;
static FILE *source_file;
/* Macros abstracting the I/O, just to make the example code clearer */
#define SOURCE_OPEN(uri) \
source_file = fopen(uri, "rb"); if (!source_file) goto error;
#define SOURCE_READ_CODEC_CONFIG_DATA(bytes, size) \
size = fread(bytes, 1, size, source_file); rewind(source_file)
#define SOURCE_READ_DATA_INTO_BUFFER(a) \
a->length = fread(a->data, 1, a->alloc_size - 128, source_file); \
a->offset = 0
#define SOURCE_CLOSE() \
if (source_file) fclose(source_file)
/** Context for our application */
static struct CONTEXT_T {
VCOS_SEMAPHORE_T semaphore;
MMAL_QUEUE_T *queue;
MMAL_STATUS_T status;
} context;
static void log_format(MMAL_ES_FORMAT_T *format, MMAL_PORT_T *port)
const char *name_type;
if(port)
fprintf(stderr, "%s:%s:%i", port->component->name,
port->type == MMAL_PORT_TYPE_CONTROL ? "ctr" :
port->type == MMAL_PORT_TYPE_INPUT ? "in" :
port->type == MMAL_PORT_TYPE_OUTPUT ? "out" : "invalid",
(int)port->index);
switch(format->type)
case MMAL_ES_TYPE_AUDIO: name_type = "audio"; break;
case MMAL_ES_TYPE_VIDEO: name_type = "video"; break;
case MMAL_ES_TYPE_SUBPICTURE: name_type = "subpicture"; break;
default: name_type = "unknown"; break;
fprintf(stderr, "type: %s, fourcc: %4.4s\n", name_type, (char *)&format->encoding);
fprintf(stderr, " bitrate: %i, framed: %i\n", format->bitrate,
!!(format->flags & MMAL_ES_FORMAT_FLAG_FRAMED));
fprintf(stderr, " extra data: %i, %p\n", format->extradata_size, format->extradata);
fprintf(stderr, " samplerate: %i, channels: %i, bps: %i, block align: %i\n",
format->es->audio.sample_rate, format->es->audio.channels,
format->es->audio.bits_per_sample, format->es->audio.block_align);
break;
fprintf(stderr, " width: %i, height: %i, (%i,%i,%i,%i)\n",
format->es->video.width, format->es->video.height,
format->es->video.crop.x, format->es->video.crop.y,
format->es->video.crop.width, format->es->video.crop.height);
fprintf(stderr, " pixel aspect ratio: %i/%i, frame rate: %i/%i\n",
format->es->video.par.num, format->es->video.par.den,
format->es->video.frame_rate.num, format->es->video.frame_rate.den);
break;
break;
default: break;
if(!port)
return;
fprintf(stderr, " buffers num: %i(opt %i, min %i), size: %i(opt %i, min: %i), align: %i\n",
port->buffer_num, port->buffer_num_recommended, port->buffer_num_min,
port->buffer_size, port->buffer_size_recommended, port->buffer_size_min,
port->buffer_alignment_min);
/** Callback from the control port.
* Component is sending us an event. */
static void control_callback(MMAL_PORT_T *port, MMAL_BUFFER_HEADER_T *buffer)
struct CONTEXT_T *ctx = (struct CONTEXT_T *)port->userdata;
switch (buffer->cmd)
case MMAL_EVENT_EOS:
/* Only sink component generate EOS events */
break;
case MMAL_EVENT_ERROR:
/* Something went wrong. Signal this to the application */
ctx->status = *(MMAL_STATUS_T *)buffer->data;
break;
default:
break;
/* Done with the event, recycle it */
mmal_buffer_header_release(buffer);
/* Kick the processing thread */
vcos_semaphore_post(&ctx->semaphore);
/** Callback from the input port.
* Buffer has been consumed and is available to be used again. */
static void input_callback(MMAL_PORT_T *port, MMAL_BUFFER_HEADER_T *buffer)
/* The decoder is done with the data, just recycle the buffer header into its pool */
/** Callback from the output port.
* Buffer has been produced by the port and is available for processing. */
static void output_callback(MMAL_PORT_T *port, MMAL_BUFFER_HEADER_T *buffer)
/* Queue the decoded video frame */
mmal_queue_put(ctx->queue, buffer);
#define ENCODING MMAL_ENCODING_RGB24
#define WIDTH 128
#define HEIGHT 128
#define MAX_ENCODINGS_NUM 25
typedef struct {
MMAL_PARAMETER_HEADER_T header;
MMAL_FOURCC_T encodings[MAX_ENCODINGS_NUM];
} MMAL_SUPPORTED_ENCODINGS_T;
int print_supported_formats(MMAL_PORT_T *port)
MMAL_STATUS_T ret;
MMAL_SUPPORTED_ENCODINGS_T sup_encodings = {{MMAL_PARAMETER_SUPPORTED_ENCODINGS, sizeof(sup_encodings)}, {0}};
ret = mmal_port_parameter_get(port, &sup_encodings.header);
if (ret == MMAL_SUCCESS || ret == MMAL_ENOSPC)
//Allow ENOSPC error and hope that the desired formats are in the first
//MAX_ENCODINGS_NUM entries.
int i;
int num_encodings = (sup_encodings.header.size - sizeof(sup_encodings.header)) /
sizeof(sup_encodings.encodings[0]);
if(num_encodings > MAX_ENCODINGS_NUM)
num_encodings = MAX_ENCODINGS_NUM;
for (i=0; i<num_encodings; i++)
printf("%u: %4.4s\n", i, (char*)&sup_encodings.encodings[i]);
return 0;
static void callback_vr_input(MMAL_PORT_T *port, MMAL_BUFFER_HEADER_T *buffer)
int main(int argc, char **argv)
MMAL_STATUS_T status = MMAL_EINVAL;
MMAL_COMPONENT_T *decoder = NULL;
MMAL_POOL_T *pool_in = NULL, *pool_out = NULL;
MMAL_BOOL_T eos_sent = MMAL_FALSE, eos_received = MMAL_FALSE;
unsigned int in_count = 0, out_count = 0;
MMAL_BUFFER_HEADER_T *buffer;
MMAL_COMPONENT_T *render = NULL;
MMAL_PORT_T *input;
MMAL_POOL_T *pool;
int i;
mmal_component_create("vc.ril.video_render", &render);
input = render->input[0];
print_supported_formats(input);
input->format->encoding = ENCODING;
input->format->es->video.width = VCOS_ALIGN_UP(WIDTH, 32);
input->format->es->video.height = VCOS_ALIGN_UP(HEIGHT, 16);
input->format->es->video.crop.x = 0;
input->format->es->video.crop.y = 0;
input->format->es->video.crop.width = WIDTH;
input->format->es->video.crop.height = HEIGHT;
mmal_port_format_commit(input);
mmal_component_enable(render);
mmal_port_parameter_set_boolean(input, MMAL_PARAMETER_ZERO_COPY, MMAL_TRUE);
input->buffer_size = input->buffer_size_recommended;
input->buffer_num = input->buffer_num_recommended;
if (input->buffer_num < 2)
input->buffer_num = 2;
pool = mmal_port_pool_create(input, input->buffer_num, input->buffer_size);
if (!pool) {
printf("Oops, ,pool alloc failed\n");
return -1;
MMAL_DISPLAYREGION_T param;
param.hdr.id = MMAL_PARAMETER_DISPLAYREGION;
param.hdr.size = sizeof(MMAL_DISPLAYREGION_T);
param.set = MMAL_DISPLAY_SET_LAYER;
param.layer = 128; //On top of most things
param.set |= MMAL_DISPLAY_SET_ALPHA;
param.alpha = 255; //0 = transparent, 255 = opaque
param.set |= (MMAL_DISPLAY_SET_DEST_RECT | MMAL_DISPLAY_SET_FULLSCREEN);
param.fullscreen = 0;
param.dest_rect.x = 100;
param.dest_rect.y = 200;
param.dest_rect.width = WIDTH;
param.dest_rect.height = HEIGHT;
mmal_port_parameter_set(input, ¶m.hdr);
mmal_port_enable(input, callback_vr_input);
for (i=0; i<10; i++) {
buffer = mmal_queue_wait(pool->queue);
// Write something into the buffer.
memset(buffer->data, (i<<4)&0xff, buffer->alloc_size);
buffer->length = buffer->alloc_size;
mmal_port_send_buffer(input, buffer);
sleep(1);
mmal_port_disable(input);
mmal_component_destroy(render);
return 0;
if (argc < 2)
fprintf(stderr, "invalid arguments\n");
return -1;
bcm_host_init();
vcos_semaphore_create(&context.semaphore, "example", 1);
SOURCE_OPEN(argv[1]);
/* Create the decoder component.
* This specific component exposes 2 ports (1 input and 1 output). Like most components
* its expects the format of its input port to be set by the client in order for it to
* know what kind of data it will be fed. */
status = mmal_component_create(MMAL_COMPONENT_DEFAULT_IMAGE_DECODER, &decoder);
CHECK_STATUS(status, "failed to create decoder");
/* Enable control port so we can receive events from the component */
decoder->control->userdata = (void *)&context;
status = mmal_port_enable(decoder->control, control_callback);
CHECK_STATUS(status, "failed to enable control port");
/* Set the zero-copy parameter on the input port */
// status = mmal_port_parameter_set_boolean(decoder->input[0], MMAL_PARAMETER_ZERO_COPY, MMAL_TRUE);
// CHECK_STATUS(status, "failed to set zero copy - %s", decoder->input[0]->name);
/* Set the zero-copy parameter on the output port */
status = mmal_port_parameter_set_boolean(decoder->output[0], MMAL_PARAMETER_ZERO_COPY, MMAL_TRUE);
CHECK_STATUS(status, "failed to set zero copy - %s", decoder->output[0]->name);
/* Set format of video decoder input port */
MMAL_ES_FORMAT_T *format_in = decoder->input[0]->format;
format_in->type = MMAL_ES_TYPE_VIDEO;
format_in->encoding = MMAL_ENCODING_JPEG;
format_in->es->video.width = 0;
format_in->es->video.height = 0;
format_in->es->video.frame_rate.num = 0;
format_in->es->video.frame_rate.den = 1;
format_in->es->video.par.num = 1;
format_in->es->video.par.den = 1;
status = mmal_port_format_commit(decoder->input[0]);
CHECK_STATUS(status, "failed to commit format");
MMAL_ES_FORMAT_T *format_out = decoder->output[0]->format;
format_out->encoding = MMAL_ENCODING_I420;
status = mmal_port_format_commit(decoder->output[0]);
/* Display the output port format */
fprintf(stderr, "%s\n", decoder->output[0]->name);
fprintf(stderr, " type: %i, fourcc: %4.4s\n", format_out->type, (char *)&format_out->encoding);
fprintf(stderr, " bitrate: %i, framed: %i\n", format_out->bitrate,
!!(format_out->flags & MMAL_ES_FORMAT_FLAG_FRAMED));
fprintf(stderr, " extra data: %i, %p\n", format_out->extradata_size, format_out->extradata);
format_out->es->video.width, format_out->es->video.height,
format_out->es->video.crop.x, format_out->es->video.crop.y,
format_out->es->video.crop.width, format_out->es->video.crop.height);
/* The format of both ports is now set so we can get their buffer requirements and create
* our buffer headers. We use the buffer pool API to create these. */
decoder->input[0]->buffer_num = decoder->input[0]->buffer_num_recommended;
decoder->input[0]->buffer_size = decoder->input[0]->buffer_size_recommended;
decoder->output[0]->buffer_num = decoder->output[0]->buffer_num_recommended;
decoder->output[0]->buffer_size = decoder->output[0]->buffer_size_recommended;
pool_in = mmal_port_pool_create(decoder->input[0],
decoder->input[0]->buffer_num,
decoder->input[0]->buffer_size);
/* Create a queue to store our decoded frame(s). The callback we will get when
* a frame has been decoded will put the frame into this queue. */
context.queue = mmal_queue_create();
/* Store a reference to our context in each port (will be used during callbacks) */
decoder->input[0]->userdata = (void *)&context;
decoder->output[0]->userdata = (void *)&context;
/* Enable all the input port and the output port.
* The callback specified here is the function which will be called when the buffer header
* we sent to the component has been processed. */
status = mmal_port_enable(decoder->input[0], input_callback);
CHECK_STATUS(status, "failed to enable input port");
status = mmal_port_enable(decoder->output[0], output_callback);
CHECK_STATUS(status, "failed to enable output port");
pool_out = mmal_port_pool_create(decoder->output[0],
decoder->output[0]->buffer_num,
decoder->output[0]->buffer_size);
while ((buffer = mmal_queue_get(pool_out->queue)) != NULL)
printf("Sending buf %p\n", buffer);
status = mmal_port_send_buffer(decoder->output[0], buffer);
CHECK_STATUS(status, "failed to send output buffer to decoder");
/* Component won't start processing data until it is enabled. */
status = mmal_component_enable(decoder);
CHECK_STATUS(status, "failed to enable decoder component");
/* Start decoding */
fprintf(stderr, "start decoding\n");
/* This is the main processing loop */
while(!eos_received && out_count < 10000)
VCOS_STATUS_T vcos_status;
/* Wait for buffer headers to be available on either of the decoder ports */
vcos_status = vcos_semaphore_wait_timeout(&context.semaphore, 2000);
if (vcos_status != VCOS_SUCCESS)
fprintf(stderr, "vcos_semaphore_wait_timeout failed - status %d\n", vcos_status);
/* Check for errors */
if (context.status != MMAL_SUCCESS)
break;
/* Send data to decode to the input port of the video decoder */
if (!eos_sent && (buffer = mmal_queue_get(pool_in->queue)) != NULL)
SOURCE_READ_DATA_INTO_BUFFER(buffer);
if(!buffer->length) eos_sent = MMAL_TRUE;
buffer->flags = buffer->length ? 0 : MMAL_BUFFER_HEADER_FLAG_EOS;
buffer->pts = buffer->dts = MMAL_TIME_UNKNOWN;
fprintf(stderr, "sending %i bytes\n", (int)buffer->length);
status = mmal_port_send_buffer(decoder->input[0], buffer);
CHECK_STATUS(status, "failed to send buffer");
in_count++;
fprintf(stderr, "Input buffer %p to port %s. in_count %u\n", buffer, decoder->input[0]->name, in_count);
/* Get our output frames */
while ((buffer = mmal_queue_get(context.queue)) != NULL)
fprintf(stderr, "asd!!!!!!\n");
/* We have a frame, do something with it (why not display it for instance?).
* Once we're done with it, we release it. It will automatically go back
* to its original pool so it can be reused for a new video frame.
eos_received = buffer->flags & MMAL_BUFFER_HEADER_FLAG_EOS;
if (buffer->cmd)
fprintf(stderr, "received event length %d, %4.4s\n", buffer->length, (char *)&buffer->cmd);
if (buffer->cmd == MMAL_EVENT_FORMAT_CHANGED)
MMAL_EVENT_FORMAT_CHANGED_T *event = mmal_event_format_changed_get(buffer);
if (event)
fprintf(stderr, "----------Port format changed----------\n");
log_format(decoder->output[0]->format, decoder->output[0]);
fprintf(stderr, "-----------------to---------------------\n");
log_format(event->format, 0);
fprintf(stderr, " buffers num (opt %i, min %i), size (opt %i, min: %i)\n",
event->buffer_num_recommended, event->buffer_num_min,
event->buffer_size_recommended, event->buffer_size_min);
fprintf(stderr, "----------------------------------------\n");
mmal_port_disable(decoder->output[0]);
//Clear out the queue and release the buffers.
while(mmal_queue_length(pool_out->queue) < pool_out->headers_num)
buffer = mmal_queue_wait(context.queue);
fprintf(stderr, "Retrieved buffer %p\n", buffer);
//Assume we can't reuse the output buffers, so have to disable, destroy
//pool, create new pool, enable port, feed in buffers.
mmal_port_pool_destroy(decoder->output[0], pool_out);
status = mmal_format_full_copy(decoder->output[0]->format, event->format);
decoder->output[0]->format->encoding = MMAL_ENCODING_I420;
decoder->output[0]->buffer_num = MAX_BUFFERS;
if (status == MMAL_SUCCESS)
fprintf(stderr, "commit failed on output - %d\n", status);
pool_out = mmal_port_pool_create(decoder->output[0], decoder->output[0]->buffer_num, decoder->output[0]->buffer_size);
else
continue;
else
fprintf(stderr, "decoded frame (flags %x, size %d) count %d\n", buffer->flags, buffer->length, out_count);
// Do something here with the content of the buffer
sleep(5);
/* Send empty buffers to the output port of the decoder */
/* Stop decoding */
fprintf(stderr, "stop decoding\n");
/* Stop everything. Not strictly necessary since mmal_component_destroy()
* will do that anyway */
mmal_port_disable(decoder->input[0]);
mmal_component_disable(decoder);
error:
/* Cleanup everything */
if (pool_in)
mmal_port_pool_destroy(decoder->input[0], pool_in);
if (pool_out)
if (decoder)
mmal_component_destroy(decoder);
if (context.queue)
mmal_queue_destroy(context.queue);
SOURCE_CLOSE();
vcos_semaphore_delete(&context.semaphore);
return status == MMAL_SUCCESS ? 0 : -1;
I didn't find an example that do what I need: decode and image and render on screen without x11.
