jezza770
Testing VC4CL with OpenCV
Fri Sep 21, 2018 10:05 am
I recently installed VC4CL as instructed from the Github repo's on my RPI3B running Raspbian Stretch and everything installed just fine.
I then installed OpenCV with OpenCL enables and that worked fine as well.
I then tried to run a Python script (with 'sudo') that uses OpenCV's detectMultiScale Haar Cascade Classifier which worked as expected, but with no speedup compared to not having VC4CL installed. The CPU was still being used. I've seen the source code so I know that the function has an OpenCL implementation.
Does anyone have any pointers on where to start debugging this? The code isn't throwing any errors or anything, just seems to skip using OpenCL altogether.
Any help would be greatly appreciated.
doe300
Re: Testing VC4CL with OpenCV
Sun Oct 21, 2018 8:17 am
The very first thing to try would be to check whether the OpenCL installation is recognized at all.
For that you can install and run the program clinfo. If it does not find the VC4CL implementation, you may need to add it to your library path (see here).
For VC4CL to be correctly read by clinfo you will need to use the clinfo version from the repository, since the package version has a bug. Also you will need to run it as root, but it will say so once VC4CL is recognized.
If this check lists VC4CL as an OpenCL implementation and it still seems to not be used, then it gets tricky. Maybe OpenCV has a way of a) forcing OpenCL to be used and b) specifying the device number (as queried by clinfo) to be used.
jezza770
Fri Oct 26, 2018 2:08 am
Thanks for the reply.
I've installed clinfo from the repo and attached a copy of the transcript from running "sudo clinfo". All seems good to me, what do you think?
Number of platforms 1
Platform Name OpenCL for the Raspberry Pi VideoCore IV GPU
Platform Vendor doe300
Platform Version OpenCL 1.2 VC4CL 0.4
Platform Profile EMBEDDED_PROFILE
Platform Extensions cl_khr_il_program cl_khr_spir cl_altera_device_temperature cl_altera_live_object_tracking cl_khr_icd cl_vc4cl_performance_counters
Platform Extensions function suffix VC4CL
Number of devices 1
Device Name VideoCore IV GPU
Device Vendor Broadcom
Device Vendor ID 0xa5c
Device Version OpenCL 1.2 VC4CL 0.4
Driver Version 0.4
Device OpenCL C Version OpenCL C 1.2
Device Type GPU
Device Profile EMBEDDED_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 1
Available core IDs 0, 64
Max clock frequency 300MHz
Device Partition (core)
Max number of sub-devices 0
Supported partition types None
Supported affinity domains (n/a)
Max work item dimensions 3
Max work item sizes 12x12x12
Max work group size 12
Preferred work group size multiple 1
Preferred / native vector sizes
char 16 / 16
short 16 / 16
int 16 / 16
long 0 / 0
half 0 / 0 (n/a)
float 16 / 16
double 0 / 0 (n/a)
Half-precision Floating-point support (n/a)
Single-precision Floating-point support (core)
Denormals No
Infinity and NANs No
Round to nearest No
Round to zero Yes
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Correctly-rounded divide and sqrt operations No
Double-precision Floating-point support (n/a)
Address bits 32, Little-Endian
Global memory size 79691776 (76MiB)
Error Correction support No
Max memory allocation 79691776 (76MiB)
Unified memory for Host and Device Yes
Minimum alignment for any data type 64 bytes
Alignment of base address 512 bits (64 bytes)
Global Memory cache type Read/Write
Global Memory cache size 32768 (32KiB)
Global Memory cache line size 64 bytes
Image support No
Local memory type Global
Local memory size 79691776 (76MiB)
Max number of constant args 64
Max constant buffer size 79691776 (76MiB)
Max size of kernel argument 256
Queue properties
Out-of-order execution No
Profiling Yes
Prefer user sync for interop Yes
Profiling timer resolution 1ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
printf() buffer size 0
Built-in kernels (n/a)
Device Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_nv_pragma_unroll cl_arm_core_id cl_ext_atomic_counters_32 cl_khr_initialize_memory cl_arm_integer_dot_product_int8 cl_arm_integer_dot_product_accumulate_int8 cl_arm_integer_dot_product_accumulate_int16
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) OpenCL for the Raspberry Pi VideoCore IV GPU
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [VC4CL]
clCreateContext(NULL, ...) [default] Success [VC4CL]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.2.11
ICD loader Profile OpenCL 2.1
Return to “Graphics programming”
