Embedded Graphics Development Platform?
Posted: Thu Sep 20, 2018 6:16 pm
by johnelle
I am finding my overpriced project clock is not meeting my needs. I wanted to develop an internet based time/weather ceiling projection system using a $30 LED projector from China and a Pi.
I am wondering if there is a stripped down OS/development platform that lets me build a full screen simple graphics interface without having to worry about windowing systems, reboots, etc. I can build it with the full (or lite) os and scripts but I was hoping maybe somebody built a stripped down OS/graphics environment for building appliance like a clock.
Python would be the preferred language.
Thanks for your suggestions.
Re: Embedded Graphics Development Platform?
Posted: Fri Sep 21, 2018 12:10 am
by topguy
I would suggest you start by developing on Raspbian Lite, maybe using PyGame or Kivy ( https://kivy.org )
When your software is finished (or at least a working prototype ) you can come back and maybe evaluate how your application can be installed and will run on even smaller distributions.
My point is.. if its a clock and probably will probably run for months without a reboot if programmed properly, does it then matter much if the boot time is 15s or 30s ?
Posted: Fri Sep 21, 2018 7:12 am
by Heater
You can build full screen graphic application with Qt that use the frame buffer directly no need for X Windows or any disk top system.
https://www.qt.io/
Last time I did this I had to build the Qt 5 libraries from source as per these instructions https://wiki.qt.io/Native_Build_of_Qt5_ ... spberry_Pi
There are newer similar instructions here https://wiki.qt.io/Native_Build_of_Qt_5 ... spberry_Pi
With this set up the Qt app can be as complex as you like and also include hardware accelerated 3D rendering using OpenGL.
Qt 5 is now available as a package in Raspbian Stretch, I don't know if it can be used without X Windows though.
The Qt 5 API can be used from Python. I have never tried that. https://wiki.python.org/moin/PyQt
Posted: Fri Sep 21, 2018 8:52 am
by Gavinmc42
$30? hmm, a few YouTubes around.
$52 Ozzie dollars plus shipping?
320x240?
Xmas is coming will add it to my Santa list.
Baremetal OpenVG Clock etc
https://ultibo.org/forum/viewtopic.php? ... 9&start=30
https://ultibo.org/forum/viewtopic.php?f=9&t=843
For graphic code testing I use USB boot mode on a Zero
https://ultibo.org/forum/viewtopic.php? ... boot#p6192
It is faster than burning SD card every time.
Others have updated via Ethernet etc as Ultibo has kernel update functions.
Posted: Sun Sep 23, 2018 11:11 am
by johnelle
Kivy looks interesting. Wasn't so much worried about minimal OS--more interested in ease of booting to a single app (which I usually do with scripts) and ease of full screen graphics development.
The projector is here: https://www.banggood.com/YG-300-LCD-Min ... &ID=47184]
Its closer to $40 but I tend to round down talking to the CFO (wife) :)
