MMAL Splitter output port cannot be changed between opaque and non-opaque
Posted: Wed Jul 25, 2018 8:17 am
by beath
I need multiple H264 video streams running in parallel at varying resolutions.
The configuration of choice is a splitter connected to the camera video port and a suitable number of video-encoders connected to the splitter outputs, either directly or using a resizer for smaller resolutions. For high resolution streams it is essential to use opaque buffers for optimal performance. For lower resolutions opaque cannot be used because the resizer does not support opaque buffers. The splitter output ports therefore need to be configured for opaque or non-opaque buffers depending on the desired resolution. With the ports of a newly created splitter this works fine.
However, once connected with opaque buffers the ports cannot be reconfigured to use non-opaque buffers, even if the ports and the connected components are correctly disabled and disconnected. Same for a change from non-opaque to opaque.
In the non-opaque to opaque case the mmal_port_format_commit returns an EINVAL error when the port is reconfigured.
In the opaque to non-opaque case no error appears but no data ever arrives at the port.
Now my questions:
Why is a disabled and disconnected splitter port different from a newly created one?
Is this an implementation bug?
Is there a trick to reset a splitter port to the initial state?
I am using a lengthy C program but the problem can easily be reproduced using a simple Picamera program:
Tested on a Raspeberry Pi3 model B+ with March 13 firmware (6e08617e7767b09ef97b3d6cee8b75eba6d7ee0b) and camera V2.1.
Program 1 (non-opaque to opaque case):
import picamera
with picamera.PiCamera(resolution = (1280, 720)) as camera:
camera.start_recording('low.h264', resize=(640, 360))
camera.wait_recording(2)
camera.stop_recording()
camera.start_recording('hi.h264')
The first recording (low) works fine but the second (hi) writes an EINVAL error to the log when the splitter port is newly configured. The hi recording still seems to work but this is because Picamera silently retries with non-opaque if an opaque connection fails.
Program 2 (opaque to non-opaque case):
import picamera
The first recording (hi) works fine. The second (low) does not throw an error but the resulting file is empty.
Re: MMAL Splitter output port cannot be changed between opaque and non-opaque
Posted: Wed Jul 25, 2018 1:59 pm
by 6by9
Where did you get that information from? vc.ril.resize supports opaque buffers on the input side quite happily.
beath wrote:I am using a lengthy C program but the problem can easily be reproduced using a simple Picamera program:
import picamera
import picamera
I'm sorry, I haven't got time to dig through PiCamera to work out the sequence of calls it is making.
If you can create a simple test case in C that I can run then I'll look at it, but not in any other language.
(And please use the code tags for code. (a) it looks nicer, and (b) it retains tabs etc which are vital in some languages).
Posted: Fri Jul 27, 2018 1:07 pm
by beath
Connecting a resizer directly to the camera works fine with opaque buffers. Connecting to a splitter output does not:
mmal: mmal_vc_port_info_set: failed to set port info (2:0): EINVAL
mmal: mmal_vc_port_set_format: mmal_vc_port_info_set failed 0x892a40 (EINVAL)
mmal: mmal_connection_create: format not set on input port
mmal: mmal_connection_destroy_internal: connection vc.ril.video_splitter:out:0/vc.ril.resize:in:0 could not be cleared
Same behaviour for "vc.ril.isp" instead of "vc.ril.resize".
You can easily reproduce this by changing the encoding types in the sample below.
Sure, here it is:
#include <stdio.h>
#include <stdlib.h> // exit()
#include <sys/time.h>
#include <time.h>
#include "bcm_host.h"
#include "interface/vcos/vcos.h"
#include "interface/mmal/mmal.h"
#include "interface/mmal/mmal_logging.h"
#include "interface/mmal/mmal_buffer.h"
#include "interface/mmal/util/mmal_util.h"
#include "interface/mmal/util/mmal_util_params.h"
#include "interface/mmal/util/mmal_default_components.h"
#include "interface/mmal/util/mmal_connection.h"
#define CAMERA_PREVIEW_PORT (0)
#define CAMERA_VIDEO_PORT   (1)
#define CAMERA_STILL_PORT   (2)
#define RESIZER "vc.ril.resize"
//#define RESIZER "vc.ril.isp"
#define AssertSuccess(r) if (r != MMAL_SUCCESS) { \
    printf(" OPERATION FAILED: %s! [%s:%d]\n", mmal_status_to_string(r), __FILE__, __LINE__); \
    exit(EXIT_FAILURE); }
static MMAL_COMPONENT_T *camera, *splitter, *resizer, *encoder;
static MMAL_CONNECTION_T *splitterConn, *resizerConn, *encoderConn;
static MMAL_POOL_T *encoderPool;
static void ControlCallback(MMAL_PORT_T *port, MMAL_BUFFER_HEADER_T *buffer)
    printf("Control callback command: %08X\n", buffer->cmd);
    mmal_buffer_header_release(buffer);
static void EncoderCallback(MMAL_PORT_T *port, MMAL_BUFFER_HEADER_T *buffer)
    if (buffer->length) {
        printf(".");
    // Cleanup and recycle buffer.
    if (encoderPool && port->is_enabled) {
        MMAL_BUFFER_HEADER_T *buf = mmal_queue_get(encoderPool->queue);
        if (buf) {
            mmal_port_send_buffer(port, buf);
static MMAL_STATUS_T SetVideoFormat(MMAL_PORT_T *port, int w, int h, int framerate)
    MMAL_ES_FORMAT_T *format = port->format;
    MMAL_ES_SPECIFIC_FORMAT_T *es = format->es;
    int alignedW = (w + 31) & ~31;
    int alignedH = (h + 15) & ~15;
    es->video.width = alignedW;
    es->video.height = alignedH;
    es->video.crop.width = w;
    es->video.crop.height = h;
    if (framerate) {
        es->video.frame_rate.num = framerate;
        es->video.frame_rate.den = 1;
    return mmal_port_format_commit(port);
static void SetupCamera(int w, int h)
    MMAL_STATUS_T res;
    res = mmal_component_create("vc.ril.camera", &camera);
    AssertSuccess(res);
    res = mmal_port_enable(camera->control, ControlCallback);
    AssertSuccess(res);
    // configure camera
    MMAL_PARAMETER_CAMERA_CONFIG_T cam_config = {
        { MMAL_PARAMETER_CAMERA_CONFIG, sizeof(cam_config) },
        .max_stills_w = w,
        .max_stills_h = h,
        .max_preview_video_w = w,
        .max_preview_video_h = h,
        .num_preview_video_frames = 3,
        .use_stc_timestamp = MMAL_PARAM_TIMESTAMP_MODE_RAW_STC
    res = mmal_port_parameter_set(camera->control, &cam_config.hdr);
    AssertSuccess(res);
    // setup camera output port
    res = SetVideoFormat(camera->output[CAMERA_VIDEO_PORT], w, h, 30);
    AssertSuccess(res);
    res = mmal_component_enable(camera);
    AssertSuccess(res);
static void ReleaseCamera()
    if (camera) {
        mmal_component_destroy(camera);
        camera = NULL;
static void ConnectSplitter(MMAL_PORT_T *sourcePort)
    MMAL_STATUS_T res;
    res = mmal_component_create("vc.ril.video_splitter", &splitter);
    AssertSuccess(res);
    sourcePort->format->encoding = MMAL_ENCODING_OPAQUE;
    sourcePort->format->encoding_variant = MMAL_ENCODING_I420;
    res = mmal_port_format_commit(sourcePort);
    AssertSuccess(res);
    res = mmal_connection_create(&splitterConn, sourcePort, splitter->input[0],
        MMAL_CONNECTION_FLAG_TUNNELLING | MMAL_CONNECTION_FLAG_ALLOCATION_ON_INPUT);
    AssertSuccess(res);
    res = mmal_component_enable(splitter);
    AssertSuccess(res);
    res = mmal_connection_enable(splitterConn);
    AssertSuccess(res);
static void DisconnectSplitter()
    if (splitterConn) {
        mmal_connection_destroy(splitterConn);
        splitterConn = NULL;
    if (splitter) {
        mmal_component_destroy(splitter);
        splitter = NULL;
static void ConnectResizer(MMAL_PORT_T *sourcePort, uint32_t encoding, int w, int h)
    MMAL_STATUS_T res;
    res = mmal_component_create(RESIZER, &resizer);
    AssertSuccess(res);
    sourcePort->format->encoding = encoding;
    AssertSuccess(res);
    MMAL_PORT_T *inPort = resizer->input[0];
    res = mmal_connection_create(&resizerConn, sourcePort, inPort,
    AssertSuccess(res);
    MMAL_PORT_T *outPort = resizer->output[0];
    mmal_format_copy(outPort->format, inPort->format);
    res = SetVideoFormat(outPort, w, h, 0);
    AssertSuccess(res);
    res = mmal_component_enable(resizer);
    AssertSuccess(res);
    res = mmal_connection_enable(resizerConn);
    AssertSuccess(res);
static void DisconnectResizer()
    if (resizerConn) {
        mmal_connection_destroy(resizerConn);
        resizerConn = NULL;
    if (resizer) {
        mmal_component_destroy(resizer);
        resizer = NULL;
static void ConnectEncoder(MMAL_PORT_T *sourcePort, uint32_t encoding)
    MMAL_STATUS_T res;
    res = mmal_component_create("vc.ril.video_encode", &encoder);
    AssertSuccess(res);
    AssertSuccess(res);
    MMAL_PORT_T *inPort = encoder->input[0];
    res = mmal_connection_create(&encoderConn, sourcePort, inPort,
    AssertSuccess(res);
    MMAL_PORT_T *outPort = encoder->output[0];
    outPort->format->encoding = MMAL_ENCODING_H264;
    outPort->format->bitrate = 1000000;
    res = mmal_port_format_commit(outPort);
    AssertSuccess(res);
    res = mmal_component_enable(encoder);
    AssertSuccess(res);
    res = mmal_connection_enable(encoderConn);
    AssertSuccess(res);
    encoderPool = mmal_port_pool_create(outPort, outPort->buffer_num, outPort->buffer_size);
    res = mmal_port_enable(outPort, EncoderCallback);
    AssertSuccess(res);
    MMAL_BUFFER_HEADER_T *buffer;
    while ((buffer = mmal_queue_get(encoderPool->queue))) {
        res = mmal_port_send_buffer(outPort, buffer);
        AssertSuccess(res);
static void DisconnectEncoder()
    if (encoder && encoder->output[0]->is_enabled) {
        mmal_port_disable(encoder->output[0]);
    if (encoderConn) {
        mmal_connection_destroy(encoderConn);
        encoderConn = NULL;
    if (encoder) {
        mmal_component_destroy(encoder);
        encoder = NULL;
int main()
    bcm_host_init();
    SetupCamera(1280, 720);
    ConnectSplitter(camera->output[CAMERA_VIDEO_PORT]);
    mmal_port_parameter_set_boolean(camera->output[CAMERA_VIDEO_PORT], MMAL_PARAMETER_CAPTURE, 1);
    // Test low resolution
    printf("test with non-opaque connection:\n");
    ConnectResizer(splitter->output[0], MMAL_ENCODING_I420, 640, 360); // does not work with MMAL_ENCODING_OPAQUE
    ConnectEncoder(resizer->output[0], MMAL_ENCODING_I420);            // does not work with MMAL_ENCODING_OPAQUE
    vcos_sleep(1000);
    printf("\n");
    DisconnectEncoder();
    DisconnectResizer();
    // Test high resolution
    printf("test with opaque connection:\n");
    ConnectEncoder(splitter->output[0], MMAL_ENCODING_OPAQUE);
    vcos_sleep(1000);
    printf("\n");
    mmal_port_parameter_set_boolean(camera->output[CAMERA_VIDEO_PORT], MMAL_PARAMETER_CAPTURE, 0);
    DisconnectSplitter();
    ReleaseCamera();
    return 0;
Swap the two test blocks in main() for the second case.
Posted: Sat Jul 28, 2018 3:01 pm
by 6by9
Thanks. I'll give it a try when I get a chance.
Posted: Fri Dec 21, 2018 1:05 pm
by beath
Update:
Meanwhile the non-opaque to opaque case works fine but changing from opaque to non-opaque still does not work correctly. There is no error replied but no data is ever received from the port after the change.
The non-working port has buffer_num_min and buffer_num_recommended set to zero which is quite unusual for a newly connected port. Maybe the wrong behavior is related to this.
Here is an updated sample:
#include <stdio.h>
#include <time.h>
static volatile int bytes;
    if (buffer->length && !(buffer->flags & MMAL_BUFFER_HEADER_FLAG_CONFIG)) {
        bytes += buffer->length;
        if (buf) {
    if (framerate) {
    MMAL_STATUS_T res;
    AssertSuccess(res);
    AssertSuccess(res);
    // configure camera
        .max_stills_w = w,
        .max_stills_h = h,
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    if (camera) {
        camera = NULL;
    MMAL_STATUS_T res;
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    if (splitterConn) {
    if (splitter) {
        splitter = NULL;
    MMAL_STATUS_T res;
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    if (resizerConn) {
        resizerConn = NULL;
    if (resizer) {
        resizer = NULL;
    MMAL_STATUS_T res;
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
    AssertSuccess(res);
        AssertSuccess(res);
    if (encoderConn) {
        encoderConn = NULL;
    if (encoder) {
        encoder = NULL;
static void TestStream()
    bytes = 0;
    printf("  buffer_num_min: %d\n", splitter->output[0]->buffer_num_min);
    vcos_sleep(1000);
    printf("  received bytes: %d\n", bytes);
int main()
    bcm_host_init();
    TestStream();
    TestStream();
    TestStream();
    TestStream();
    ReleaseCamera();
    return 0;
This is the output:
  buffer_num_min: 1
  received bytes: 79211
  buffer_num_min: 3
  received bytes: 108773
  buffer_num_min: 0
  received bytes: 0
  buffer_num_min: 3
  received bytes: 102905
