pfaure
how to stop screen saver while program is running
Tue Oct 10, 2017 1:04 am
I have a Raspberry PI 3, with a 7" display. I am running a python program with Kivy. There are times during the running of my program that the display is un-touched, but the program is still updating the screen with new information. Is there a way to stop the OS from making the screen go blank during those times? I don't want to disable the screen saver, just make it think that there was an input during certain parts of my application.
Thank you
topguy
Re: how to stop screen saver while program is running
Tue Oct 10, 2017 11:08 am
Are you running X-Windows or not ?
Kivy is using the GPU/dispmanx directly if I recall correctly, so its not really touching the standard "console" nor the "X-Windows desktop".
If you run without X and its the 60 second console timeout that triggers you might be able to simulate output on that console by writing text to "/dev/tty1".
So boot normally to console, wait until blank and then log in via SSH and test the command.
echo "Hello" > /dev/tty1
Who is online
Users browsing this forum: No registered users and 1 guest
