Strange behaviour of mailbox calls
Sun Sep 24, 2017 8:31 am
I have some user defined code that I want to execute on the VideoCore IV GPU. I can execute this code either via a mailbox-call or via register-poking, writing directly into the V3D registers (see functions gpu_fft_base_exec_direct and gpu_fft_base_exec of ... fft_base.c). Additionally, I'm executing the code several successive times on all QPUs.
Now, executing the code via directly poking the registers (in a loop: writing the V3D registers, waiting for all interrupts) works perfectly. Executing the same code via the mailbox interface shows some strange behavior:
  • If there is some delay (e.g. 10 ms) between mailbox-calls, the execution finishes successfully.
  • If there is no delay between the mailbox-calls, after a few loop-iterations, the system freezes, no response, not even in terminals.
  • If I set the delay between the syscalls to a lower value (e.g. 100 us), the execution finished, but significantly (about 1/8th) slower!
My theory for the first two points is, that I somehow swamp the linux kernel with syscalls, so it has no more time for anything else!? But I can't explain why a lower delay results in a slower execution.
Has anyone here an explanation for this behaviour?
Re: Strange behaviour of mailbox calls
Tue Jan 02, 2018 12:30 pm
Don't have an answer to your question, however want to work on the same way. With GPU_FFT , I try to use mbox method instead of direct_execute : no success. I run it on Raspberry PiZero/Raspbian Stretch. Have you modify something in gpu_fft_base.c ?
Who is online
Users browsing this forum: No registered users and 4 guests
