cmarty
How to free unused dispmanx layer (in case of SIGSEGV)
Thu Sep 07, 2017 10:57 am
Hello.
I have opengl app (using openframeworks).
I try to solve the situation when my program receive SIGSEGV (or for debug purpose I send him SIGSEGV signal) the program do not free dispmanx layer (resource) and last state of this dispmanx layer is still present on display. When I run program again the old dispmanx layer is still present and new dispmanx layer is created. Is there any way how I can remove, delete the old unused dispmanx layer/resource ?
For list of active dispmanx layers i use command "vcgencmd dispmanx_list"
Re: How to free unused dispmanx layer (in case of SIGSEGV)
Thu Sep 07, 2017 11:50 am
Trap the SIG, do the dispmanx deallocation in the handler?
Martin Frezman
Thu Sep 07, 2017 11:56 am
Well, yes, but i assume the question is more: How do i do this after the fact? I.e., what if it has already happened?
Also:
$ vcgencmd dispmanx_list
error=1 error_msg="Command not registered"
Thu Sep 07, 2017 12:32 pm
Also:
Nothing possible 'after it has happened' I suspect, without updated firmware. Big red switch time.But will double check with the dispmanx experts.
blackshard83
Tue Sep 26, 2017 11:51 am
AFAIK there is no documented way for a process to get the handle to a dispmanx layer of another process, so you can't free it after the leak.
Though I never tried to store the dispmanx handles somewhere (maybe on the filesystem) and let another process pick them up and do the calls to free them. From a process separation point of view dispmanx should not allow such thing, although it should automatically clean the garbage when the process dies... :roll:
Martin Frezman
Tue Sep 26, 2017 12:46 pm
This sounds like a good exercise for the OP - given that he has, in his possession, a program that can crash, leaving a layer still visible. It sounds like he has most of what he needs at his fingertips.
All you need to do is add code to write out the handle to a file before the crash.
jwatte
Wed Oct 18, 2017 2:14 am
Are you sure the process has actually died? If you check for it with "ps aux | grep <procname>" is it still alive?
It sounds like a pretty bad driver bug if somehow the OS lets resources stay allocated after a process goes away.
6by9
Wed Oct 18, 2017 8:53 am
Checking the firmware source there is handling for the VCHIQ service closing, and it does free up all resources.
As a quick test, taking hello_dispmanx and inserting a div0 before the sleep, the overlay comes up, and is then cleared up as the app. It is going through that VCHIQ service closing handler.
"vcgencmd dispmanx_list" was added to the firmware in September 2015. Are you running very old firmware? What does "vcgencmd version" report?
"vcgencmd commands" will list all the available commands that are registered.
Return to “Graphics programming”
