Jouke
gtk+css problem
Wed Aug 30, 2017 6:16 pm
Hi all,
I have a problem with gtk+ version 3.22.11 on a raspberry pi running raspbian.
Not sure if this is the right place so please tell me if I have to ask somewhere else.
I build a small test GUI with glade (see debug.glade) and a python demo (debug.py) using a css (test.css) to change the fontsize of a label.
This works fine on my PC running Ubuntu and Gtk version version 3.18.9 (see PC.png) but the font size change is ignored on my RPI (see RPI.png)
The question is: is this a GTK issue or a raspbian issue ?
Thanks for your help,
Jouke
debug.tgz
(988 Bytes) Downloaded 63 times
matteohammer
Re: gtk+css problem
Sun Nov 05, 2017 4:53 pm
Hi, i have the same problem. Did you solve it ?
namannik
Re: gtk+css problem
Mon Feb 12, 2018 11:37 pm
Similar issue here. When attempting to apply a style from the following CSS, the font color is changed, but nothing I can do will affect the font size.
label {
  color: #FF0000;
  font-size: 10px;
PeterO
Re: gtk+css problem
Sun Mar 25, 2018 12:24 pm
I suspect this is another consequence of the RPI guys trying to enforce their world view on everyone ! :evil:
I need a monospaced font in a gtktextview, but nothing I've tried works. It's VERY annoying when their changes invalidate lots of tutorials and documentation etc.
PeterO
Interests: C,Python,PIC,Electronics,Ham Radio (G0DZB),Aeromodelling,1960s British Computers.
PeterO
Re: gtk+css problem
Sun Mar 25, 2018 1:51 pm
I've found a solution....
The key seems to be so set a high enough priority for the provider. The example I had found at
https://stackoverflow.com/questions/431 ... -text-view
used GTK_STYLE_PROVIDER_PRIORITY_APPLICATION which has a value of 600 but that didn't seem high enough to
override the theme setting
Using GTK_STYLE_PROVIDER_PRIORITY_USER (value 800) seems to do the trick !
    display = gdk_display_get_default ();
    screen = gdk_display_get_default_screen (display);
    provider = gtk_css_provider_new();
    gtk_style_context_add_provider_for_screen (screen, GTK_STYLE_PROVIDER (provider), GTK_STYLE_PROVIDER_PRIORITY_USER);
    error = NULL;
    gtk_css_provider_load_from_file (provider, g_file_new_for_path("./my.css"), &error);
my.css
textview {
    font-family: monospace;
PeterO
namannik
Re: gtk+css problem
Sun Mar 25, 2018 6:09 pm
I've found that the cause of this problem is this file:
/home/pi/.config/gtk-3.0/gtk.css
It overrides the font size set in other applications by using a * selector:
  font-size: 12pt;
By removing this section of the file, I was able to use CSS to set the font size in my own application.
PeterO
Re: gtk+css problem
Sun Mar 25, 2018 6:22 pm
Good find. I did see that file but obviously I didn't look close enough at its contents!
But using "*" seems like a lazy method to employ.
PeterO
MaxNodehi
Re: gtk+css problem
Mon Apr 16, 2018 10:58 pm
I have the same problem, but none of these solutions solved my problem. I get the font color, but not font-size neither font-family.
Return to “Graphics programming”
Who is online
Users browsing this forum: No registered users and 2 guests
