ntwk
Understanding the 'priority' argument in vc_dispmanx_update_
Fri Nov 25, 2016 8:14 pm
I am trying to write some code using the Dispmanx API. The lack of documentation has meant that it's been a slow learning process. I have been using the hello_dispmanx example program has been my primary reference.
As I understand it, drawing operations must first start with a call to
vc_dispmanx_upate_start()
and then end with a call to
vc_dispmanx_update_submit_sync()
which flushes the changes to the display.
vc_dispmanx_update_start() accepts a single 'priority' argument. In the hello_dispmanx example the 'priority' argument is assigned a value of 10. All of the other examples I have come across pass in a value of 0.
I have the following questions:
  • 1. What does the 'priority' argument do?
    2. What are the acceptable values for 'priority'?
    3. Why is 'priority' assigned a value of 10 in the hello_dispmanx example?
