atlantis86
Graphics library for framebuffer writting
Tue Nov 15, 2016 12:58 pm
I am using ILI9341 based LCD display in one of my projects, utilizing Raspberry Pi Zero.
I was able to install it under system. Display is visible as /dev/fb1.
Now I am looking for some simple C library, which allow me to do some basic graphic operations (printing text, drawing lines and circles, displaying simple bitmaps). Simple menu system would also be nice. Basically - I am looking for something similar to popular Arduino graphic libraries, but designed to use /dev/fb1 as low level IO device.
Morphology
Re: Graphics library for framebuffer writting
Mon Nov 21, 2016 7:29 pm
I have been on the same journey. The excellent series by -rst- gives a good overview of writing directly to the framebuffer, and covers displaying lines, squares, circles, images and simple bitmap text:
http://raspberrycompote.blogspot.co.uk/ ... _9509.html
The problem is that /fb1 on the Raspberry Pi doesn't benefit from hardware graphics acceleration, and most of the Graphics libraries around won't work without modification. So what I decided to do is use raylib (www.raylib.com) which is a really simple and easy to use Graphics library and write to /fb0 then use raspi2fb to mirror this to /fb1 that way you get the benefit of graphics acceleration writing to /fb0 and can display the results on /fb1
It's not exactly the solution you want but, strangely, I found I got better performance this way than trying to write directly to /fb1
Morph
Return to “Graphics programming”
