I need hello_video to run on layer 2...I want to put a graphic overlay on the video
Could anyone tell me how to mod hello_video to make it play on layer 2?
Otherwise, I am willing to pay someone to mod hello_video with that and a couple of other things.
- Raspberry Pi Engineer & Forum Moderator
- Location: ZZ9 Plural Z Alpha, aka just outside Cambridge.
Re: hello_video hack...
Untested, but adding
to the source at a point after the component has been created and before it is changed to executing. Straight after the "set_tunnel" calls would be about perfect.
OMX_CONFIG_DISPLAYREGIONTYPE region;
memset(®ion, 0, sizeof(OMX_CONFIG_DISPLAYREGIONTYPE));
region.nSize = sizeof(OMX_CONFIG_DISPLAYREGIONTYPE);
region.nVersion.nVersion = OMX_VERSION;
region.nPortIndex = 90;
region.layer = 2;
region.set |= OMX_DISPLAY_SET_LAYER;
if(video_decode != NULL && OMX_SetParameter(ILC_GET_HANDLE(video_decode), OMX_IndexConfigDisplayRegion, ®ion) != OMX_ErrorNone)
status = -40;
Thank you. That is awesome.
I pasted in the code and it compiles but exits when I try to test it. Commenting out the code causes it to work again.
set_tunnel(tunnel, video_decode, 131, video_scheduler, 10);
set_tunnel(tunnel+1, video_scheduler, 11, video_render, 90);
set_tunnel(tunnel+2, clock, 80, video_scheduler, 12);
region.layer = 2;
status = -40;
// setup clock tunnel first
if(status == 0 && ilclient_setup_tunnel(tunnel+2, 0, 0) != 0)
status = -15;
else
ilclient_change_component_state(clock, OMX_StateExecuting);
if(status == 0)
ilclient_change_component_state(video_decode, OMX_StateIdle);
memset(&format, 0, sizeof(OMX_VIDEO_PARAM_PORTFORMATTYPE));
format.nSize = sizeof(OMX_VIDEO_PARAM_PORTFORMATTYPE);
format.nVersion.nVersion = OMX_VERSION;
format.nPortIndex = 130;
format.eCompressionFormat = OMX_VIDEO_CodingAVC;
region.layer = 2;
status = -40;
status = -15;
else
if(status == 0)
Sorry, silly typo
if(video_render != NULL && OMX_SetParameter(ILC_GET_HANDLE(video_render), OMX_IndexConfigDisplayRegion, ®ion) != OMX_ErrorNone)
(render, not decode).
Is it possible to tweak it a bit more to accept layer number as argument on the command line?
It is possible to set the layer via a command line parameter. Use sscanf or atoi on argv.
hello_video is a very simple example app, therefore I'm not going to be making that sort of change.
