RogerW
Re: tkinter panedWindow
Thu Sep 15, 2016 1:35 pm
I think part of the problem is that you do not need to pack the widgets in the paned window - you have to add them.
import tkinter as tk
root = tk.Tk()
root.title("Panes")
root.geometry("200x100")
panes = tk.PanedWindow(root,orient = "horizontal",showhandle = True)
panes.pack()
left = tk.Label(root,text = "Left")
right = tk.Label(root,text = "Right")
panes.add(left)
panes.add(right)
root.mainloop()
This does allow the panes to be resized but is only a start.
RogerW
Fri Sep 16, 2016 8:31 am
PanedWindow does not seem to be very well documented. I have not been able to find much on its correct use.
This slightly more elaborate version of my previous post might help.
# create main window
main = tk.Tk()
main.title("Panes")
# create a paned window and place it on the main window
paned = tk.PanedWindow(main,orient = tk.HORIZONTAL,showhandle = True,width = 200)
paned.grid()
# create two text boxes to go directly on the paned window
left = tk.Label(main,text = "Left")
right = tk.Label(main,text = "Right")
# create a frame to contain two more text boxes
frame = tk.Frame(main)
upper = tk.Label(frame,text = "Upper")
lower = tk.Label(frame,text = "Lower")
upper.grid(row = 0)
lower.grid(row = 1)
# add the widgets to the pained window
# they will be set left to right
paned.add(left)
paned.add(frame)
paned.add(right)
# now start the program
main.mainloop()
