Slofware
Runn python code in a loop after GUI start
Thu Jul 28, 2016 3:36 pm
After I start a GUI in python that I made in Qt creator 5 with the instruction app.exec_() I still want to loop some other python code.
How can I do that?
scotty101
Re: Runn python code in a loop after GUI start
Thu Jul 28, 2016 3:42 pm
It depends on whether you just want the task to happen periodically or or an event.
If you want to do it periodically in the background then I'd suggest a timer.
http://stackoverflow.com/questions/3236 ... ng-a-timer
The timer will periodically call a function that contains the code that you wish to run.
Your code should not contain an infinite loop, you are relying on the QT timer to call your function again and again periodically.
Slofware
Fri Jul 29, 2016 12:15 pm
Thanx that worked perfect!!
Now the next thing, how can I read or write in python to for example a Slider in the GUI?
