Model loaders for Rasbian and Linux generally
Posted: Fri Jul 22, 2016 10:20 pm
by Brian Beuken
Hi
Can anyone recommend a good basic open source model loader which will work for Raspbian. I don't want to limit it solely to OBJ but I do need to keep the footprint to a minimum, but
I've hunted around and most open srouce seem very DirectX or OpenGL based often with Windows in mind and I really needs something that will work on the Raspbian and a few other SBC flavours of Linux.
It also needs to be very easy to use, as this is part of a tutorail for beginners and I need to avoid long detailed explinations of how to use it. So a plug and play lib, or a compile sub project style approach is best.
thanks
Re: Model loaders for Rasbian and Linux generally
Posted: Sun Jul 24, 2016 10:17 pm
by raysan5
Maybe you can try my library: raylib (www.raylib.com)
It supports multiple platforms, minimal dependencies, supports OBJ loading, materials, shaders...
More info on Raspberry Pi usage: https://github.com/raysan5/raylib/wiki/ ... spberry-Pi
Please, let me know if you try it!
Posted: Mon Jul 25, 2016 12:07 pm
by Brian Beuken
thanks but i really just need a model loader, not a full graphics library, this is for teaching beginner level programmers how to code, so an engine sorta defeats that purpose.
If you made your model loaders as a seperate stand along lib i'd be very interested
