fredfs
Kill the CLI frambebuffer
Wed Apr 20, 2016 4:40 pm
Hello, I would like to play images and videos, and use negative frambeffer numbers (example, omxplayer --layer '-10')
But the command prompt at frambuffer 0 stays on top of negative buffer.
I dont use the command prompt, how can I kill it, or prevent it from starting at all?
jojopi
Re: Kill the CLI frambebuffer
Wed Apr 20, 2016 5:03 pm
According to "omxplayer --help", higher layers are on top, so I do not understand what you want -10 to do.
I have never seen the kernel framebuffer above omxplayer. Rather, if the aspect ratio of the video does not match your display, you will see the framebuffer around the edges. "omxplayer -b" solves that.
Changing physical resolution with "tvservice" has the side effect of breaking the kernel framebuffer until it is reinitialized with "fbset".
fredfs
Thu Apr 21, 2016 3:35 am
How can I kill the tty1 framebuffer or prevent it from starting at all?
AndyD
Fri Apr 22, 2016 9:42 am
fredfs wrote:How can I kill the tty1 framebuffer or prevent it from starting at all?
From memory if you use the tvservice command to change the video mode, the framebuffer is destroyed. Have a look at Changing video resolution on the fly?
dividuum
Fri Apr 22, 2016 6:30 pm
The default console layer is -127 or something, so -10 should still result in a visible the omxplayer output. In info-beamer, I basically use this (except written in C):
echo 1 > /sys/class/graphics/fb0/blank
This removes the console. You can restore it by writing '0' instead of '1'.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
fredfs
Thu May 05, 2016 2:16 pm
Omxplayer has a strage behavior when on negative layer (example -10), if there is a tranaprant png layer over it, you dont see omxplayer layer. If omxplayer is on layer zero or above, you can render transparent png over it without problems.
Why?
