mslinklater
Windowed OpenGLES sample
Fri Jan 01, 2016 8:40 pm
Hi. I'm an experienced C++ graphics programmer but pretty dumb at Linux. Does anyone know of any sample code for the Pi to bring up a window in X with GLES running in it ?
-rst-
Re: Windowed OpenGLES sample
Wed Jan 06, 2016 2:50 pm
As far as I know, on the RPi there is no X to GL(ES) integration (like GLX) yet - the X window and the GLES 'window' need to be created separately and made to align in your application code (which might lead to the GLES to lag behind when dragging the X window - for example Minecraft seemed to suffer from this) or some sort of copy pixels from an EGL context to the X window must be implemented like https://github.com/PaulHaeberli/pi-eglonx (possibly slow).
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
mung
Sun Jan 10, 2016 10:23 pm
mslinklater wrote:Hi. I'm an experienced C++ graphics programmer but pretty dumb at Linux. Does anyone know of any sample code for the Pi to bring up a window in X with GLES running in it ?
I think you may find it best to wait until the anholt drivers are released (rumours have it they should be around 1st quarter 2016)
Otherwise you will need to do a lot of work yourself working out color conversion or making sure the framebuffer is in correct BPP format.
I think you could check this thread viewtopic.php?f=63&t=74651&
Pablo Walters
Sun Nov 27, 2016 6:24 am
I just made this work again for Raspberry PI 3 Model B
It is a nice simple way to get OpenGLES2.0 running inside
a window when running PIXEL on RPI 3 Model B
