HowardPrice
SDL2 hardware acceleration
Tue Oct 06, 2015 1:53 pm
It seems that the Jessie sdl2 package is not built with OpenGL ES hardware acceleration.
SDL_CreateRenderer( &window, -1, SDL_RENDERER_ACCELERATED | SDL_RENDERER_PRESENTVSYNC);
fails with "Couldn't find matching render driver"
So I resorted to building SDL2 from source as outlined in this article:
https://solarianprogrammer.com/2015/01/ ... ted-sdl-2/
which involves configuring prior to make with:
../configure --disable-pulseaudio --disable-esd --disable-video-mir --disable-video-wayland --disable-video-x11 --disable-video-opengl
Now when I run my test program SDL_CreateRenderer succeeds, but the rendering is still very slow. I suspect that I am not getting true hardware acceleration, but some form of software implementation.
If I list the available video drivers with SDL_GetNumVideoDrivers and SDL_GetVideoDriver I get two: "RPI" and "dummy".
How can I ensure that I have true hardware acceleration using OpenGL ES when I build SDL2 ?
exobuzz
Re: SDL2 hardware acceleration
Sat Oct 10, 2015 2:40 am
If it's useful you can use the RetroPie-Setup script to get a working SDL2 installed with HW acceleration
https://github.com/RetroPie/RetroPie-Setup
clone it, and then you can just do
sudo ./retropie_packages.sh sdl2
to build/install new SDL2 debs.
tvjon
Sun Oct 11, 2015 9:07 am
Thank you kindly.
It took < an hour to build that lot & seemed to install without problems, & it looks like Stella may work accelerated now :)
