About SDL2 freeze
Posted: Mon Sep 21, 2015 10:27 am
by davidsu
I write a game in this board ,
I use SDL2 as my 2D library,
But the game is always random freeze
I use
sudo vcdbg reloc
to dump GPU status
I find "heap corruption detected" in the end of the dump message
How can I find the corrupt position ?
or any other information to help me to solve the problem
the attachment file is the dump message.
sorry about my bad english.
Tks.
Re: About SDL2
Posted: Thu Sep 24, 2015 4:02 am
by davidsu
I have some extra information
I use Raspberry Pi 2 with 1G ram,
and resolution 1920x1080 p 60
When it freeze , I use ssh connect to the system and dump some message
It freeze because of "futex_" and in eglSwapBuffers ()
But the same program , when I change config.txt to
hdmi_group=2 (DMT)
hdmi_mode=81 1366x768 60 Hz
It is not freeze ,
I think it is freeze because of egl or driver.
Adn the same program , I disable Loading Message when the png and wav file loading(without use any 2D graphic function) ,
and the resolution is 1920x1080 p 60 ,and It is not freeze too ,
pi@raspberrypi ~/crush $ uname -a
Linux raspberrypi 4.1.7-v7+ #815 SMP PREEMPT Thu Sep 17 18:34:33 BST 2015 armv7l GNU/Linux
pi@raspberrypi ~/crush $ ps -al
F S UID PID PPID C PRI NI ADDR SZ WCHAN TTY TIME CMD
4 S 1000 2331 2318 0 80 0 - 1570 wait tty1 00:00:00 bash
4 S 0 2351 2331 0 80 0 - 1150 poll_s tty1 00:00:00 sudo
4 S 0 2352 2351 0 80 0 - 1071 wait tty1 00:00:00 run.sh
4 S 0 2353 2352 39 80 0 - 24105 futex_ tty1 00:00:43 S.SB00.1
0 R 1000 2383 2364 0 80 0 - 1038 - pts/0 00:00:00 ps
pi@raspberrypi ~/crush $ cd sb_game/
pi@raspberrypi ~/crush/sb_game $ sudo ./dd.sh
(gdb) attach 2353
Attaching to process 2353
Reading symbols from /home/pi/crush/sb_game/Build/ENG.S.SB00.1/Release/S.SB00.1...done.
Reading symbols from /usr/lib/arm-linux-gnueabihf/libcofi_rpi.so...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/arm-linux-gnueabihf/libcofi_rpi.so
Reading symbols from /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSAllegro.0.1.so...done.
Loaded symbols for /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSAllegro.0.1.so
Reading symbols from /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSMain.0.1.so...done.
Loaded symbols for /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSMain.0.1.so
Reading symbols from /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSRand.0.1.so...done.
Loaded symbols for /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSRand.0.1.so
Reading symbols from /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSSys.0.1.so...done.
Loaded symbols for /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSSys.0.1.so
Reading symbols from /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSDriver.0.1.so...done.
Loaded symbols for /home/pi/crush/agos/Target/S.ENG/0.0/Release/libGameOSDriver.0.1.so
Reading symbols from /usr/local/lib/libSDL2-2.0.so.0...done.
Loaded symbols for /usr/local/lib/libSDL2-2.0.so.0
Reading symbols from /lib/arm-linux-gnueabihf/libpthread.so.0...(no debugging symbols found)...done.
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0x730c3460 (LWP 2358)]
[New Thread 0x73959460 (LWP 2357)]
[New Thread 0x74159460 (LWP 2356)]
[New Thread 0x74959460 (LWP 2355)]
[New Thread 0x75159460 (LWP 2354)]
Loaded symbols for /lib/arm-linux-gnueabihf/libpthread.so.0
Reading symbols from /usr/local/lib/libSDL2_image-2.0.so.0...done.
Loaded symbols for /usr/local/lib/libSDL2_image-2.0.so.0
Reading symbols from /usr/local/lib/libSDL2_ttf-2.0.so.0...done.
Loaded symbols for /usr/local/lib/libSDL2_ttf-2.0.so.0
Reading symbols from /usr/local/lib/libSDL2_mixer-2.0.so.0...done.
Loaded symbols for /usr/local/lib/libSDL2_mixer-2.0.so.0
Reading symbols from /usr/lib/arm-linux-gnueabihf/libstdc++.so.6...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/arm-linux-gnueabihf/libstdc++.so.6
Reading symbols from /lib/arm-linux-gnueabihf/libm.so.6...(no debugging symbols found)...done.
Loaded symbols for /lib/arm-linux-gnueabihf/libm.so.6
Reading symbols from /lib/arm-linux-gnueabihf/librt.so.1...(no debugging symbols found)...done.
Loaded symbols for /lib/arm-linux-gnueabihf/librt.so.1
Reading symbols from /lib/arm-linux-gnueabihf/libgcc_s.so.1...(no debugging symbols found)...done.
Loaded symbols for /lib/arm-linux-gnueabihf/libgcc_s.so.1
Reading symbols from /lib/arm-linux-gnueabihf/libc.so.6...(no debugging symbols found)...done.
Loaded symbols for /lib/arm-linux-gnueabihf/libc.so.6
Reading symbols from /opt/vc/lib/libbcm_host.so...(no debugging symbols found)...done.
Loaded symbols for /opt/vc/lib/libbcm_host.so
Reading symbols from /lib/arm-linux-gnueabihf/libdl.so.2...(no debugging symbols found)...done.
Loaded symbols for /lib/arm-linux-gnueabihf/libdl.so.2
Reading symbols from /lib/ld-linux-armhf.so.3...(no debugging symbols found)...done.
Loaded symbols for /lib/ld-linux-armhf.so.3
Reading symbols from /usr/lib/arm-linux-gnueabihf/libfreetype.so.6...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/arm-linux-gnueabihf/libfreetype.so.6
Reading symbols from /lib/arm-linux-gnueabihf/libz.so.1...(no debugging symbols found)...done.
Loaded symbols for /lib/arm-linux-gnueabihf/libz.so.1
Reading symbols from /lib/arm-linux-gnueabihf/libpng12.so.0...(no debugging symbols found)...done.
Loaded symbols for /lib/arm-linux-gnueabihf/libpng12.so.0
Reading symbols from /opt/vc/lib/libvcos.so...done.
Loaded symbols for /opt/vc/lib/libvcos.so
Reading symbols from /opt/vc/lib/libvchiq_arm.so...(no debugging symbols found)...done.
Loaded symbols for /opt/vc/lib/libvchiq_arm.so
Reading symbols from /lib/arm-linux-gnueabihf/libudev.so.0...(no debugging symbols found)...done.
Loaded symbols for /lib/arm-linux-gnueabihf/libudev.so.0
Reading symbols from /usr/lib/arm-linux-gnueabihf/libjpeg.so.8...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/arm-linux-gnueabihf/libjpeg.so.8
Reading symbols from /opt/vc/lib/libGLESv2.so...(no debugging symbols found)...done.
Loaded symbols for /opt/vc/lib/libGLESv2.so
Reading symbols from /opt/vc/lib/libEGL.so...(no debugging symbols found)...done.
Loaded symbols for /opt/vc/lib/libEGL.so
0x755b4770 in sem_wait@@GLIBC_2.4 ()
(gdb) back
#0 0x755b4770 in sem_wait@@GLIBC_2.4 ()
#1 0x730cf538 in eglSwapBuffers () from /opt/vc/lib/libEGL.so
#2 0x75693f2c in SDL_EGL_SwapBuffers (_this=<optimized out>,
egl_surface=<optimized out>) at /home/pi/SDL2-2.0.3/src/video/SDL_egl.c:461
#3 0x756a0770 in SDL_GL_SwapWindow_REAL (window=0x11572b8)
at /home/pi/SDL2-2.0.3/src/video/SDL_video.c:3010
#4 0x7563c484 in SDL_RenderPresent_REAL (renderer=<optimized out>)
at /home/pi/SDL2-2.0.3/src/render/SDL_render.c:1800
#5 0x756292a0 in SDL_RenderPresent (a=<optimized out>)
at /home/pi/SDL2-2.0.3/src/dynapi/SDL_dynapi_procs.h:381
#6 0x757399d0 in vsync () at allegro/c/allegro.cpp:916
#7 0x00040790 in WaitVsync () at shell/c/main.cpp:583
#8 0x00040bb8 in vSystemProcessBlitUnit () at shell/c/main.cpp:793
#9 0x0000d06c in vStartGame (ptr=0x0) at main/c/game_main.cpp:932
#10 0x0000d11c in main (argc=1, argv=0x7e9fd7d4) at main/c/game_main.cpp:947
(gdb)
Re: About SDL2
Posted: Thu Oct 08, 2015 8:05 am
by davidsu
More information about my problem,
some times the screen will not show all of the image(see attach)
and freeze.
the OS still working , and I can ssh to the OS,
but it can not run this program again , only reboot can resolve it
anyone have any idea ???
Please help me.
Re: About SDL2
Posted: Wed Oct 14, 2015 6:56 am
by davidsu
I have a small program will repeat the "freeze problem"
I follow the step of this link to install SDL2 https://solarianprogrammer.com/2015/01/ ... ted-sdl-2/
This is my config.txt , I changed gpu_mem to 640
# For more options and information see
# http://www.raspberrypi.org/documentatio ... fig-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
gpu_mem=640
about my source program ,
It can compile with
"g++ -std=c++0x -Wall -pedantic sdl2_test.cpp -o sdl2_test `sdl2-config --cflags --libs` -lSDL2_image"
1.please tar -zxvf test_sdl_logo.tar.gz to the same folder of the program
2.please put a png file with resolution (1920*1080) file to the same folder and rename to 1.png
then run the program , it will freeze after 30 sec.
if anyone have any idea please help me,thank you everybody.
Re: About SDL2 freeze
Posted: Thu Oct 15, 2015 2:54 am
by davidsu
Additional information ,
I follow the step of this link https://github.com/raspberrypi/userland/issues/254
I found some assert message , but it is occur before freeze.
pi@raspberrypi ~ $ sudo vcdbg log assert
001336.074: assert( source ) failed; ../../../../../middleware/confzilla/cp_front_fdt.c::cp_front_fdt_load_builtin line 115
002040.266: assert( card not initialised ) failed; ../../../../../filesystem/media/sdcard/sdcard.c::sdhost_close line 1045
pi@raspberrypi ~ $
