Mariusmssj4
glDrawArrays only handles up to 65535 points
Mon May 11, 2015 12:57 pm
Hi guys,
Seems to have an issue with OpenGLES2.0 as it can only draw up to 65535 on my:
glDrawArrays(GL_POINTS, 0, pointCount); //307200 points
call.
So is there any way to increase the point count for the call?
Thanks.
RaTTuS
Contact: Twitter YouTube
Re: glDrawArrays only handles up to 65535 points
Mon May 11, 2015 1:08 pm
GLsizei is probably 16bit
so cannot be increased
Covfefe
Mariusmssj4
Mon May 11, 2015 1:25 pm
Yeah it seems to be the case, is it possible to make up a point cloud out of multiple 65535 point segments?
e.g:
glVertexAttribPointer(posAttrib, 4, GL_FLOAT, GL_FALSE, 8 * sizeof(GLfloat), (GLvoid *)segment1);
glEnableVertexAttribArray(posAttrib);
glDrawArrays(GL_POINTS, 0, 65535);
glVertexAttribPointer(posAttrib, 4, GL_FLOAT, GL_FALSE, 8 * sizeof(GLfloat), (GLvoid *)segment2);
glVertexAttribPointer(posAttrib, 4, GL_FLOAT, GL_FALSE, 8 * sizeof(GLfloat), (GLvoid *)segment3);
Paeryn
Mon May 11, 2015 6:55 pm
Mariusmssj4 wrote:Yeah it seems to be the case, is it possible to make up a point cloud out of multiple 65535 point segments?
There shouldn't be a problem. Although in your code you showed you call glEnableVertexAttribArray(posAttrib); three times, you only need to enable it the first time, it'll stay active until you disable it with glDisableVertexAttribArray (posAttrib);
You might be able to get away with not setting the array pointer each time, instead just add 65536 to first of glDrawArrays().
glDrawArrays(GL_POINTS, 65536, 65535);
glDrawArrays (GL_POINTS, 131072, 65535);
Mariusmssj4
Tue May 12, 2015 8:41 am
Thanks for the replies guys :)
Paeryn the change of starting point didn't work so I wrote a for loop and changed the starting pointer on the array. This is the draw call now and it works:
void Renderer::draw(pcl::PointCloud<pcl::PointXYZRGB>::Ptr pointCloud)
	// Set the viewport
	glViewport(0, 0, this->GScreenWidth, this->GScreenHeight);
	//Clear colour buffer
	glClearColor(0.0f, 0.8f, 0.8f, 1.0f);
	glClear(GL_COLOR_BUFFER_BIT);
	if (pointCloud->size() == 0)
		return;
	pcl::PointXYZRGB *pointPtr = &pointCloud->points[0];
	size_t pointCount = pointCloud->points.size();
	int segments = pointCount / 65535;
	int lowSegm = pointCount % 65535; //307200
	//Use program object
	glUseProgram(this->programObject);
	//Get attribute location
	GLint posAttrib = glGetAttribLocation(this->programObject, "position");
	for (int i = 0; i <= segments; i++)
		float  * ptrV = (float*)(&pointPtr[65535 * i]);
		//Load vertex data
		glVertexAttribPointer(posAttrib, 4, GL_FLOAT, GL_FALSE, 8 * sizeof(GLfloat), (GLvoid *)(ptrV));
		if (i < segments)
		else
			glDrawArrays(GL_POINTS, 0, lowSegm);
	glDisableVertexAttribArray(posAttrib);
	eglSwapBuffers(this->GDisplay, this->GSurface);
